Who wants to take a stab at my rear end?
#339481
06/06/09 11:57 AM
06/06/09 11:57 AM
Posts: 1,476 Oh
RacerGofKGB
Got The Big One
Got The Big One
Oh
I was out and about looking for a Dana 60 today and came across two rearends that i dont believe are dana 60s, but am curious to know what they are anyway. The two in the middle are the ones in question: Here is a close up of the one on top. And another close up. Here is the one on the bottom. And another shot of the bottom one. Anybody know what these are?
Re: Who wants to take a stab at my rear end?
[Re: RacerGofKGB]
#339482
06/06/09 12:27 PM
06/06/09 12:27 PM
Posts: 7,506 Az
Crizila
Az
Looks like a 9 1/4 out of a truck.
Fastest 300
[Re: RacerGofKGB]
#339492
06/06/09 10:40 PM
06/06/09 10:40 PM
I quickly Googled this up: http://www.powerwagonadvertiser.com/forums/showthread.php?t=6002Here's the thing: a 44 looks very similar to a 60, it's just smaller. You need to Google around and get dimensions so you can measure the rear cover. Spicer/ Dana made all kinds of differentials, I think there's a 70, and there's a 53, 30, 20 something, etc. on down.
[Re: patrick]
#339493
06/07/09 12:14 AM
06/07/09 12:14 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
never seen a full float 9 1/4, only 5 lug semi float (or 6 lug from a dako
There are full float 9 1/4's out there in 1 ton vans.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: RacerGofKGB]
#339496
06/08/09 10:00 PM
06/08/09 10:00 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
Well i pulled the two rear ends out today and had a better look at them both. The one with the two ribs is deffinatly a Dana 60HD. The one with the really wide rib, i am going to assume is a 60. The cover plates are interchangable between the two and many other measurements i took were the same. The 60HD had this stamped into the ring gear: 7 8 77 DANA 30360 A3D94X 41-10 (297) the 297 was upside down compared to the rest.
The other rear had this stamped into the ring gear: 3 12 76 DANA 36787 B3D35X 43-13 (754) The 754 was also upside down.
Im going to assume the first set of numbers are the dates: July 8. 1977 and March 12, 1976. The other numbers are a mystery.
As far as the housings go, the 60HD only had "60HD" cast into it. I could find no other numbers on it.
The one with the wide band only had "C-37717" and "82-76" cast into it.
i'm no Dana expert but i bet those numbers are tooth count on ring and pinion. 41-10: 41 ring gear, 10 pinion. 41-10=4.10 ratio. 43-13= 3.30
