Who wants to take a stab at my rear end? #339481
06/06/09 11:57 AM
06/06/09 11:57 AM
Oh
RacerGofKGB Offline OP
Got The Big One
Got The Big One
Oh
I was out and about looking for a Dana 60 today and came across two rearends that i dont believe are dana 60s, but am curious to know what they are anyway.
The two in the middle are the ones in question:
Here is a close up of the one on top.
And another close up.
Here is the one on the bottom.
And another shot of the bottom one.
Anybody know what these are?
Re: Who wants to take a stab at my rear end? [Re: RacerGofKGB] #339482
06/06/09 12:27 PM
06/06/09 12:27 PM
Az
Crizila Offline
Crizila  Offline
Az
Looks like a 9 1/4 out of a truck.
Fastest 300
Re: Who wants to take a stab at my rear end? [Re: RacerGofKGB] #339483
06/06/09 12:33 PM
06/06/09 12:33 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
The top ones are danas, probably 60's out of trucks.
Re: Who wants to take a stab at my rear end? [Re: RacerGofKGB] #339484
06/06/09 12:39 PM
06/06/09 12:39 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
"Who wants to take a stab at my rear end? "
ummmm.....no thanks
Re: Who wants to take a stab at my rear end? [Re: Pacnorthcuda] #339485
06/06/09 12:53 PM
06/06/09 12:53 PM
chicagoland,usa
chicagoland,usa
I was staying out of the gutter from the get go.
Re: Who wants to take a stab at my rear end? [Re: buildanother] #339486
06/06/09 12:58 PM
06/06/09 12:58 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Talk about a sexual "inyourendo"...
Re: Who wants to take a stab at my rear end? [Re: RacerGofKGB] #339487
06/06/09 03:53 PM
06/06/09 03:53 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
The first one looks like a 60 out of a newer ford van and the second one is a 60HD
Re: Who wants to take a stab at my rear end? [Re: 446acuda] #339488
06/06/09 06:52 PM
06/06/09 06:52 PM
Oh
Got The Big One
Got The Big One
Oh
Neither one of these housings had a "60" cast into the flange like i thought they were supposed to. Is there another way to identify them?
Re: Who wants to take a stab at my rear end? [Re: Crizila] #339489
06/06/09 08:57 PM
06/06/09 08:57 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
never seen a full float 9 1/4, only 5 lug semi float (or 6 lug from a dakota)
9 1/4's also have a pretty much perfect octagonal rear cover.
2017 Grand Cherokee Overland
Re: Who wants to take a stab at my rear end? [Re: RacerGofKGB] #339490
06/06/09 09:57 PM
06/06/09 09:57 PM
chicagoland,usa
chicagoland,usa
Only the one on the bottom of the stack in pic #4 looks to be a 9 1/4 to me. There's also a 1/2 ton gen mot truck job in one of them pics.
Re: Who wants to take a stab at my rear end? [Re: buildanother] #339491
06/06/09 10:23 PM
06/06/09 10:23 PM
Oh
Got The Big One
Got The Big One
Oh
Yea the one with the rubber plug in the cover is the 9 1/4. There were atleast two of them in the pile there. Also a few 9", some 83/4 and some GM rears.
Re: Who wants to take a stab at my rear end? [Re: RacerGofKGB] #339492
06/06/09 10:40 PM
06/06/09 10:40 PM
I quickly Googled this up:
http://www.powerwagonadvertiser.com/forums/showthread.php?t=6002
Here's the thing: a 44 looks very similar to a 60, it's just smaller. You need to Google around and get dimensions so you can measure the rear cover. Spicer/ Dana made all kinds of differentials, I think there's a 70, and there's a 53, 30, 20 something, etc. on down.
Re: Who wants to take a stab at my rear end? [Re: patrick] #339493
06/07/09 12:14 AM
06/07/09 12:14 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
There are full float 9 1/4's out there in 1 ton vans.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Who wants to take a stab at my rear end? [Re: Rug_Trucker] #339494
06/07/09 06:58 PM
06/07/09 06:58 PM
Oh
Got The Big One
Got The Big One
Oh
Well i pulled the two rear ends out today and had a better look at them both. The one with the two ribs is deffinatly a Dana 60HD. The one with the really wide rib, i am going to assume is a 60. The cover plates are interchangable between the two and many other measurements i took were the same.
The 60HD had this stamped into the ring gear:
7 8 77 DANA 30360 A3D94X 41-10 (297) the 297 was upside down compared to the rest.
The other rear had this stamped into the ring gear:
3 12 76 DANA 36787 B3D35X 43-13 (754) The 754 was also upside down.
Im going to assume the first set of numbers are the dates: July 8. 1977 and March 12, 1976. The other numbers are a mystery.
As far as the housings go, the 60HD only had "60HD" cast into it. I could find no other numbers on it.
The one with the wide band only had "C-37717" and "82-76" cast into it.
Re: Who wants to take a stab at my rear end? [Re: RacerGofKGB] #339495
06/08/09 09:05 AM
06/08/09 09:05 AM
Oh
Got The Big One
Got The Big One
Oh
The both had 30 spline axles and neither one was a limited slip. I wouldnt be so lucky. However, I can have my choice, and the price is right..free. So would one be better than the other? Or are they about the same, just grab one and go. I lifted them up above my head a few times and neither is noticably heavier than the other, so i dont think weight will be much of a factor.
Re: Who wants to take a stab at my rear end? [Re: RacerGofKGB] #339496
06/08/09 10:00 PM
06/08/09 10:00 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
i'm no Dana expert but i bet those numbers are tooth count on ring and pinion. 41-10: 41 ring gear, 10 pinion. 41-10=4.10 ratio. 43-13= 3.30
Re: Who wants to take a stab at my rear end? [Re: RacerGofKGB] #339497
06/08/09 10:08 PM
06/08/09 10:08 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Measure the axle tube diameter. The 60HD's often have a slightly larger diameter (3 1/8") than the regular 3" car axles. Not a huge deal but if you go with the larger tube you will need bigger U-bolts as well as redrilling/reaming the shock plates.
Re: Who wants to take a stab at my rear end? [Re: PC-CHARGER] #339498
06/13/09 04:08 PM
06/13/09 04:08 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
looks like jeep rears
