How to proceed with bodywork?
#338974
06/05/09 06:35 PM
06/05/09 06:35 PM
Posts: 1,113 Lost in Pooler, GA
Gumbydammit
Lost in Pooler, GA
I am wondering where to go from where I am with my Dart. Dennis at DMC racecars installed frame connectors and hung the quarters for me. I had another professional do the rest of the bodywork up to this point. As it sits, it is covered in an epoxy primer that was baked on. The guide coat was put on after. Since I was going to move, I paid my bill, and had the car shipped to my new house. I have sand blasted the engine compartment and filled the unneccessary holes. I have a Sears Craftsman HVLP siphon cup spray gun, longbord hand sander , small sanding block, and a craftsman 5HP 20 gallon oil less compressor. I bought some 2k primer and I would like to prime the engine compartment, trunk area ( still needs to be sanded and cleaned ), and door jambs. Basically, I'd like to get it ready to paint. What materials will I need? Cleaners, sandpaper grit, etc. The car isn't going to be a show car, but since I've gone this far, I may as well make it nice. Any and all advice is welcome. I have a basic understanding of bodywork, and my Father has painted several trucks for a Fleet, but nothing really on a professional level. Hopefully, the pictures I am posting will work.
Thanks.
I'm Gumby dammit!
Re: How to proceed with bodywork?
[Re: Gumbydammit]
#338979
06/05/09 06:50 PM
06/05/09 06:50 PM
Posts: 571 Western NC
68Bullit
Western NC
And let a professional take it from this point on ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: 68Bullit]
#338982
06/05/09 10:17 PM
06/05/09 10:17 PM
DaytonaTurbo
Manitoba, Canada
Sure, sounds like a plan. Just let me borrow your credit card and we'll be good to go. ![](/ubbthreads/images/graemlins/beer.gif)
Seriously though, find the 'p-sheets' for your primer. The p-sheet will tell you what kind of a grit to sand to, what ratios to mix reducers, what kinds of surfaces the primer can be applied to, etc. Those tech sheets for the product you are using are very valuable to the diy'er.
Other than what the sheet says you need, you'll need a degreaser and some tack cloths. I suggest picking up a junk fender and practicing on there first, getting the product to lay down nicely and cleanly before moving on to your car. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Neil]
#338984
06/05/09 11:38 PM
06/05/09 11:38 PM
Posts: 1,047 Arizona
68CoronetRT
Arizona
Try this link: http://www.southernpolyurethanes.com/perfect%20paint.htmMy guess is your compressor is too small to keep up with an HVLP gun. What is the CFM requirement of your spray gun? Compare that to the output of your compressor. The compressor should provide about 1 1/2 times the amount the gun uses especially with a small tank. If you are just going to spray the primer you could get away with doing a panel at a time but once you go to spraying color especially if it is a metallic you should have the car assembled and paint it all at one time.
