ign timing question
#338622
06/05/09 12:22 PM
06/05/09 12:22 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I am interested in how much initial timing people run in their motor, as i'm having overheating problems. My engine is 440 11-1 comp, crane roller 670/670 lift, .280@50 108, Dart 3050 without driver, 4500 j converter, 4.56 gears 29.5 slicks. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: ign timing question
[Re: Quicktree]
#338624
06/05/09 12:28 PM
06/05/09 12:28 PM
deaks
robin hood country
Do you think my setup needs 22, or would you recommend i lock it out. Just worried about starter breakage.
[Re: deaks]
#338626
06/05/09 12:47 PM
06/05/09 12:47 PM
Quicktree
try it, I don't like locking it out
[Re: deaks]
#338627
06/05/09 01:30 PM
06/05/09 01:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I am interested in how much initial timing people run in their motor, as i'm having overheating problems. My engine is 440 11-1 comp, crane roller 670/670 lift, [Email].280@50[/Email] 108, Dart 3050 without driver, 4500 j converter, 4.56 gears 29.5 slicks. Mick
You could be just lean, hows the idle... if your at 18 your in the ball park... I would check for a vac leak or just lean
[Re: MR_P_BODY]
#338628
06/05/09 03:06 PM
06/05/09 03:06 PM
deaks
robin hood country
It doesn;t idle well at all, carb is hp 950 82 prim, 84 secs and i think 6.5 pvs back and front. What are the symptoms of a vac leak. Mick
[Re: deaks]
#338629
06/05/09 05:33 PM
06/05/09 05:33 PM
MR_P_BODY
Take a can of spray carb cleaner/brake cleaner and spray around the intake to heads and around the carb base, if its leaking it will increase in rpm.... thats the easiest way to check. Do your plugs look whiter on one bank than the other, that would likely be a intake gasket a carb base gasket would show lean on all of them
[Re: deaks]
#338630
06/05/09 07:10 PM
06/05/09 07:10 PM
Posts: 15,491 the boonies
aarcuda
the boonies
with a cam that big you're vacuum at idle must be low. Prob 6-8. You need a lower power valve to start. 2.5-4.5
