ign timing question #338622
06/05/09 12:22 PM
06/05/09 12:22 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I am interested in how much initial timing people run in their motor, as i'm having overheating problems.
My engine is 440 11-1 comp, crane roller 670/670 lift, .280@50 108, Dart 3050 without driver, 4500 j converter, 4.56 gears 29.5 slicks.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: ign timing question [Re: deaks] #338623
06/05/09 12:25 PM
06/05/09 12:25 PM
Q
Quicktree Offline
Quicktree  Offline
Q
18-22 gets the job done in most cases.
Re: ign timing question [Re: Quicktree] #338624
06/05/09 12:28 PM
06/05/09 12:28 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Do you think my setup needs 22, or would you recommend i lock it out. Just worried about starter breakage.
best 60ft 1.36
Re: ign timing question [Re: deaks] #338625
06/05/09 12:36 PM
06/05/09 12:36 PM
mine is 16 to 18 at 800 RPM depending on the track and elevation, 34 to 36 total
Re: ign timing question [Re: deaks] #338626
06/05/09 12:47 PM
06/05/09 12:47 PM
Q
Quicktree Offline
Quicktree  Offline
Q
try it, I don't like locking it out
Re: ign timing question [Re: deaks] #338627
06/05/09 01:30 PM
06/05/09 01:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My engine is 440 11-1 comp, crane roller 670/670 lift, [Email].280@50[/Email] 108, Dart 3050 without driver, 4500 j converter, 4.56 gears 29.5 slicks.
Mick
You could be just lean, hows the idle... if your at
18 your in the ball park... I would check for a vac
leak or just lean
Re: ign timing question [Re: MR_P_BODY] #338628
06/05/09 03:06 PM
06/05/09 03:06 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
It doesn;t idle well at all, carb is hp 950 82 prim, 84 secs and i think 6.5 pvs back and front.
What are the symptoms of a vac leak.
Mick
best 60ft 1.36
Re: ign timing question [Re: deaks] #338629
06/05/09 05:33 PM
06/05/09 05:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mick
Take a can of spray carb cleaner/brake cleaner and spray
around the intake to heads and around the carb base,
if its leaking it will increase in rpm.... thats the
easiest way to check. Do your plugs look whiter
on one bank than the other, that would likely be
a intake gasket a carb base gasket would show lean
on all of them
Re: ign timing question [Re: deaks] #338630
06/05/09 07:10 PM
06/05/09 07:10 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
Mick
with a cam that big you're vacuum at idle must be low. Prob 6-8. You need a lower power valve to start. 2.5-4.5
