Page 1 of 3 1 2 3
How much power can a 426 Hemi make? #338454
06/05/09 08:10 AM
06/05/09 08:10 AM
the frozen wastes...
Pale_Roader Offline OP
Swears too much
Swears too much
Just curious. It seems to be getting easier to squeeze a solid 600HP from a non-stroked 440 these days with all the aftermarket heads out there. What about a hemi? How hard is it to make say, 700HP naturally aspirated with a stock stroke 426? A few guys i know say its as simple as cleaning up the heads, blueprinting the valvetrain and using a serious solid/solid roller cam and a good intake/exhaust set-up?
How much power have hemi owners typically built for something driven on the street? What would a 700HP street 426 hemi be like? Technology has come a long way.
And i've also wondered how much power the old 426 hemi stock cars made?
We're always talking about this stuff here, the usual bench racin'... and no one has owned one, just figured i'd ask here and get some real input. I'm sure there are a few hemi owners/ex-owners here.
Re: How much power can a 426 Hemi make? [Re: Pale_Roader] #338455
06/05/09 08:51 AM
06/05/09 08:51 AM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
For what its worth, mine makes a shade over 600 with old iron heads, old school TRW pistons, NASCAR rods, and a .640 lift roller, with a cross ram and two Holley 660's. Stock stroke, 434 inches, 6600 rpm.
Far from exotic, it is basically a SS engine from the sixties, with a little less camshaft (most of them used old R296 Cranes)and smaller carbs.
With newer stuff, 700 hp is pretty easy.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: How much power can a 426 Hemi make? [Re: Steve1118] #338456
06/05/09 12:49 PM
06/05/09 12:49 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
The top SS Hemi engines are making more than 900 HP. They actually are slightly larger due to overbore, but are still 438-440 CID. I think a 426 Hemi with newer heads like a Millenium head and all the tricks and no port limitations and bigger carbs could get up to around 1000 HP, but that would be a guess on my part. I was told a CW Hemi engine runs upward of $75k, so that's well out of my price range (about 3X).
Floyd Lippencott IV
Re: How much power can a 426 Hemi make? [Re: Steve1118] #338457
06/05/09 12:55 PM
06/05/09 12:55 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
815Hp, 640TQ, 438 ci, 1970 casting iron heads w stock valve sizes, 11.3 compression, 2-625 Carter carbs, good intake, aggressive roller cam, 2.25 headers, mid 1990's technology.
Be a Rebel- Break the Laws of Physics!
Re: How much power can a 426 Hemi make? [Re: mbogina] #338458
06/05/09 05:47 PM
06/05/09 05:47 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Yup, 800hp is pretty attainable with good heads on a 426 + 0.030" over. I was making in excess of 600hp with my first 426 hemi...The heads are the key, and you can spend as much as you want in that area. Best heads for it are Stage V Millenium heads at that level or RBRE SS heads which are Stage V anyways....
Re: How much power can a 426 Hemi make? [Re: Dragula] #338459
06/05/09 06:10 PM
06/05/09 06:10 PM
Northeast, Arkansas
Dodgeman67 Offline
Dodgeman67  Offline
Northeast, Arkansas
Great thread guys, I was wondering the same thing.
I'm gathering parts for my 426 as we speak.
Here is what I have and yall tell me what kind of power it will make, or maybe what other parts I need.
I have a 426 MP block stock bore with a stock stroke crank, the MP aluminum heads, an older Weiand 2 - 4 tunnel ram intake that I will have to Ron's flying toilets alcohol injection, I have some Canadian roller rockers, 13.5 - 1 Venolia pistons, and some Keith Black aluminum rods.
What roller cam do I need to make the most power? I also have to buy lifters, pushrods, and valve springs, and maybe valves.
What header tube size do I need, and on these I plan to build a 540" short block later to put in the car under my current top end, so what header size will I need for it and I will build them now.
It's going in our racecar, no street driving.
With the right cam, what kind of power are we looking at?
Re: How much power can a 426 Hemi make? [Re: Dragula] #338460
06/05/09 06:14 PM
06/05/09 06:14 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I hope to squeeze out 800+Hp with the new engine which is a little bit bigger than a stock 426 engine. I really think to make good power with the the Hemi, the design really likes good cylinder pressure, and responds well to larger cams.
Here is some flow numbers with today's technology.
I'm hoping the added stroke and bore will lower the engines power band some, which will really make it a nice bracket engine that isn't killing its self every run with 7500-8000 rpm passes.
http://www.moparmusclemagazine.com/techa...test/index.html
^^^ Here is a great article on what can be expect out of a mild crate Hemi with just some bolt on parts. I bet the engine would pickup another 12-15% more in power if the compression was up there in the 12-13:1 range.
Re: How much power can a 426 Hemi make? [Re: Dodgeman67] #338461
06/05/09 06:51 PM
06/05/09 06:51 PM
Steve1118 Offline
Steve1118  Offline
I couldn't give you a power figure....but it will be plenty.
I know absolutely nothing about Ron's toilets, and I have never used aluminum rods. I always found them a bit scary.
Everything I use is pre-historic, but I know it and it's reliable. Besides, I'm a dinosaur. Brother Bob told me so.
Re: How much power can a 426 Hemi make? [Re: Steve1118] #338462
06/05/09 07:40 PM
06/05/09 07:40 PM
Swears too much
Swears too much
Crazy stuff. So, despite all the recent developments in wedge head technology, the hemi is still a level above in potential? Even the older hemi heads? I'm no hemi expert, but the newer designs dont immediately look much different than the older ones. With the wedge heads, the difference is night and day. Sounds like a 700HP N/A street hemi wouldn't be too hard to build.
Also, i meant the old stock cars, not the drag cars. What were those 70's stock cars making right before they got banned?
Re: How much power can a 426 Hemi make? [Re: Pale_Roader] #338463
06/05/09 08:33 PM
06/05/09 08:33 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Im sure Chuck Lofgren won the Hemi Challenge with a prep'd set of 68 stock Cast Iron Hemi heads, all other contestants were running Indy or Stage V heads. They also had the smallest engine of the contest too..
Here is a article.
http://www.moparmusclemagazine.com/eventcoverage/mopp_0602_hemi_challenge_engine_build/index.html
Re: How much power can a 426 Hemi make? [Re: Steve1118] #338464
06/05/09 08:40 PM
06/05/09 08:40 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Steve:
I have some of that old stuff in mine too. I run NASCAR rods and a 440 steel crank in my junk. But it runs great and has held together for quite some time now.
MB
Re: How much power can a 426 Hemi make? [Re: HPMike] #338465
06/05/09 09:12 PM
06/05/09 09:12 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
A 700 HP "426" CI Hemi would be lots O fun on the street, but miserable to drive very far. A 500+ inch 700 HP hemi would be lots O fun too, but much nicer to drive around.
Re: How much power can a 426 Hemi make? [Re: mbogina] #338466
06/05/09 09:17 PM
06/05/09 09:17 PM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
This motor is incredible considering those parts! I wish you were closer Mike, I'd offer you a couple of for . The curve is a lot steeper than people think.
Re: How much power can a 426 Hemi make? [Re: RAT PATROL] #338467
06/05/09 11:13 PM
06/05/09 11:13 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
F.A.S.T. Hemi's are getting 1.5 HP per CI with original heads, intake and exhaust manifolds, AFB carbs, and cams the idle smoothly.
Take away any of those limitations, and a Hemi will really fly!
Hemi's really love stroker cranks and big cams.
If your building a hemi from scratch, there's no reason to stick with the little 3.75 crank, unless you are working within a set of rules that require it. The price ends up about the same for a stock or a stroker crank.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: How much power can a 426 Hemi make? [Re: Hemi_Joel] #338468
06/06/09 12:24 AM
06/06/09 12:24 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
My 472 has heavy crate pistons and rods, but a 650 roller, massaged alum. Mopar heads, milled -3 Indy with a Dom, and its a very streetable 620, 535 at the rear. Very expensive on fuel, but idles @ 850 and loves 3500 rpm cruising. 10.75 compression. I agree , those numbers above are very nice. Wish I went with lighter pistons and a hair higher compression, but I love the cam.
DT, I'd like to take your dyno-winner on a short ride with you.. Maybe at Carlisle.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: How much power can a 426 Hemi make? [Re: Hemi_Joel] #338469
06/06/09 12:43 AM
06/06/09 12:43 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
im working on our 426 hemi stock stoke (kellog crank) and stock bore id really like to get a close guiess hp as to what it will make
the combo is...
stock stroke/bore
alum rods
stx-22 solid roller racer brown super stock grind (think it was 590/613 315 260@.50) something like that
uncut raised port dual plug dick landy heads
11.5-compression (run on street)
tunnel ram(weiand) with 2 1050 domnator carbs
2 inch header (i know lil on small side)
balanced , msd-7,crank trigger
so what would be a honest hp guiess based on what you guys know about hemis also what safe rpm limit with this combo?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: How much power can a 426 Hemi make? [Re: sunroofgtx] #338470
06/06/09 09:37 AM
06/06/09 09:37 AM
Lebanon,IN
mr2performance Offline
Lebanon,IN
Hey Rick, anymore info on your camshaft? I'm building a similar engine right now. Mike Roth
MR2PERFORMANCE RACE CARS 765 483 9371
Re: How much power can a 426 Hemi make? [Re: toplescuda] #338471
06/06/09 12:22 PM
06/06/09 12:22 PM
Dragula Offline
Dragula  Offline
I had a similar sized cam in my +0.030" 426 and a tunnel ram with 11.6:1 compression, and it was between 585hp and 625hp with unported Indy heads. The head flow numbers will get you a better guess.
If DLI is still around, give them a call and find out right from them. The 800hp number I quoted was from a Barton SS motor single 4bl with 12.5:1 compression and a nasty cam not attainable without line boring the cam journals out. The heads they said had almost a full 40hrs of porting into them according to the article. Basically his SS heads on a milder motor for bracket racing.
Every point of compression is about 70-80hp on one of these motors.
Re: How much power can a 426 Hemi make? [Re: Dragula] #338472
06/06/09 12:36 PM
06/06/09 12:36 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
i made just shy of 800 hp with my 477 (4.15x4.28) stock block, callies crank, manley/barton rods, je pistons(12:1), stage V sr heads (light port/polish job) t&d/barton valvetrain, mopar performance x-ram (right outta the box, ports are tiny compared to the head) bone stock 68 hemi x-ram carbs(actually jetted 79's squared on all primary sides) bullet cam which is relatively small, made 797hp @6900 and 630 tq@5800 drive it on the street very often,uses alot of fuel but even with the turbo action j convertor its not a real handful
Re: How much power can a 426 Hemi make? [Re: prochargedhemi] #338473
06/06/09 04:18 PM
06/06/09 04:18 PM
Northeast, Arkansas
Dodgeman67 Offline
Dodgeman67  Offline
Northeast, Arkansas
Here is my other block with the top end sitting on it. You know these hemis are pretty dang big.
Page 1 of 3 1 2 3
