Re: Double pumper vs vacuum secondary
[Re: chargers777]
#338389
06/05/09 07:13 AM
06/05/09 07:13 AM
Posts: 565 IA
landon1
IA
my 71 is 440/auto/highway gears...and i love my DP - they say they're not good for heavy automatic cars, but i'm sure lots of people have been putting them on since they came out. I had nothing but problems with VS Holley carbs, and i think the DP is the best carb (i've heard GREAT things about TQs from a local guy, but never tried one)
'71 Satellite Sebring 440
[Re: Crizila]
#338391
06/05/09 11:04 AM
06/05/09 11:04 AM
Posts: 531 Virginia
JimG
Virginia
You definitely do NOT want a double pumper for your application. Heavy car + stock 440 + 3.23's + auto trans(I assume) = bad. A double pumper is not for you, stick to a vacuum secondary carb. If you want a spread bore carb, do what I do and run a thermoquad. It runs great on my 440 in my satellite plus gets good fuel mileage for what it is.
Got my vote!
I learned this lesson at young age. I had a '78 440 Fury cop car. Heavy car, tight converter, low (numerically) rear end gears. Long story short, I put an 800 double pumper on it. What a dog! You had to feather-foot the throttle until the RPM came up, or it was very evident that the car was slowing down as the throttle was increased. You had to learn how to drive the car and always be aware of throttle position, and gradually increase the throttle as the revs came up. After I got tired of that nonsense, I ran a non-lean burn Thermoquad on the same car and it ran great. It didn't look all racy and cool like the double pumper, but you could smack the throttle to the floor any time and the carb did the rest.
I've also run Holley 3310s (750 Vac sec) on mild 440s with great results after tweaking. So have a zillion other folks.
My advice - don't make the same expensive mistake I made when I was young and foolish. TQ or Holley VS would be my recommendation.
[Re: chargers777]
#338392
06/05/09 01:19 PM
06/05/09 01:19 PM
DaytonaTurbo
Manitoba, Canada
I have the 73 850 cfm thermo quad that came on it and it ran ok.Thermo quads just seem problematic to me and holley are easy to work on and find parts for.
TQ's are harder to get parts for, but everything is out there. I've been using my thermoquad in my 440 as my daily driver for 6 years and it will light the tires on demand. But I did invest some time tuning the choke and the secondaries.
If a DP's what you want, send me a pm, I've got a 650cfm holley spreadbore DP with a complete holley jet kit I would sell. 650dp is probably the best size for a combo like yours.
[Re: chargers777]
#338393
06/05/09 07:14 PM
06/05/09 07:14 PM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
I've used what you are describing: 800 DP spreadbore Holley, fresh stock rebuit 440, heavy car, 3.23 and an auto with 12" stock converter. The car ran great. Fried the tires at will at any speed in 1st gear. That was 20 years ago and I still have the carb mounted on the intake with fuel line and air cleaner sitting in storage ready to go. I've loaned it out to others as-is and they all had very good results as well.
This was with a stock cam, factory spreadbore intake, and exhaust manifolds, but the engine was fresh and an honest 10:1 CR. We did run it on a low comp. stock-like 440 GTX and it ran very well too.
[Re: 68Bullit]
#338395
06/05/09 10:52 PM
06/05/09 10:52 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Run a TQ. I wont run ANYTHING else on a street car
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
