REPLACING A/C EVAPORATOR ~ 97 DAKOTA #338337
06/04/09 10:24 PM
06/04/09 10:24 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Evap has finally gotten to where it won't hold a charge but a couple days. Should I tackle this or let the pro's do this?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: REPLACING A/C EVAPORATOR ~ 97 DAKOTA [Re: Magnumguy] #338338
06/05/09 10:03 PM
06/05/09 10:03 PM
S.E.Ohio
S.E.Ohio
Re: REPLACING A/C EVAPORATOR ~ 97 DAKOTA [Re: Magnumguy] #338339
06/05/09 10:12 PM
06/05/09 10:12 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I did mine(2000) dakota. I spent 1/2 day one day, then 1/2 day the next. I used a tip from a dealer guy and took the coolant hoses off at the engine and dragged them through the firewall with the box. I dropped steering column onto drivers seat, disconnected the main dash harness under dash, pulled dash back enough to wrestle the box outta there, did have to dig through the foil insulation at firewall to remove a few screws on engine bay side. Wasn't as bad as I thought it was gonna be, but still kindof involved. The most irritating part to me was trying to re-clip the a/c lines at evap connection w/out ruining the very thing I was replacing.
Re: REPLACING A/C EVAPORATOR ~ 97 DAKOTA [Re: buildanother] #338340
06/05/09 10:33 PM
06/05/09 10:33 PM
S.E.Ohio
S.E.Ohio
Cool.
I had heard there's a special tool for those clips?
Re: REPLACING A/C EVAPORATOR ~ 97 DAKOTA [Re: Magnumguy] #338341
06/05/09 10:39 PM
06/05/09 10:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You can get a cheap one at the parts store.
Re: REPLACING A/C EVAPORATOR ~ 97 DAKOTA [Re: stumpy] #338342
06/06/09 09:01 AM
06/06/09 09:01 AM
S.E.Ohio
S.E.Ohio
so there is one? What's it called, so I don't look like the amatuer I am when I go in to get one
Re: REPLACING A/C EVAPORATOR ~ 97 DAKOTA [Re: Magnumguy] #338343
06/06/09 09:06 AM
06/06/09 09:06 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
REALLY depends on your capabilaties.
I'm not trying to scare you out of a job but it's not for the faint of heart.If you do it, Make sure to disconnect the battery BEFORE you remove anything then let it set about 20 minutes. this is a job that could easily blow the airbags if your not carefull.
Lots of brackets to remove,both a-pillar mouldings, upper dash applique, both kickpanels, wiring to dis-connect, drop the steering column, drain the cooling system and with light air pressure flush the coolant out of the heater core to prevent spillage on the interior floor/carpeting. No way I would drag the heater hoses in with it. you'll have enough to wrestle around without the hoses flopping around with it.
Re: REPLACING A/C EVAPORATOR ~ 97 DAKOTA [Re: Magnumguy] #338344
06/06/09 10:06 AM
06/06/09 10:06 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Well if it's anything like the one in my wifes 99 jeep it's a PITA. the entire dash has to come out. Cost around $1000 for that and the heater core. 8 hours of labor and well worth it.
Coming soon!!!!
Re: REPLACING A/C EVAPORATOR ~ 97 DAKOTA [Re: Mr.Yuck] #338345
06/06/09 12:47 PM
06/06/09 12:47 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Replace the heater core while you are there.I most times recommended changing the blower motor if it has lots of miles.Either one goes bad and you will be doing it again.Rocky
Chrysler Firepower
