Will a 1.625 valve spring work on a 440-1?
#338327
06/04/09 09:44 PM
06/04/09 09:44 PM
Posts: 761 KY
juicedcuda
KY
Like it says above, will a 1.625 valve spring work on a -1 head without modification?
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
Re: Will a 1.625 valve spring work on a 440-1?
[Re: juicedcuda]
#338330
06/04/09 10:59 PM
06/04/09 10:59 PM
Posts: 4,696 On the parachute mount
n20mstr
the pocket will need to be opened, and watch that the edges can get thin and will "peel" later. Make sure they blend any thin areas so they cant break off later on, My heads were opened up to get a 1.625 spring on there
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#338331
06/04/09 11:06 PM
06/04/09 11:06 PM
Posts: 761 KY
juicedcuda
KY
I think now I am going to order new springs and retainers in 1.550. I already have some titanium retainers that are 1.625 and wanted to find a spring that would work in the pocket unmodified and fit the retainers I had but comp discontinued the spring that I found. I really don't want to modify the pocket for the reasons you mentioned.
1970 Plymouth 'Cuda
1973 Gold Duster
[Re: juicedcuda]
#338332
06/04/09 11:10 PM
06/04/09 11:10 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Juiced, I'm sure there are guys who've made it work, or gotten away with it. I wanted to use the direct bolt-on T&D rockers, and they told me to avoid being forced to use thiers, or Jesels, individual pedestal style, which require machining of the head, I should NOT use the 1.625 size. I went with 1.550.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#338335
06/04/09 11:18 PM
06/04/09 11:18 PM
n20mstr
i use the bolt on T & D with my 1.625 springs, All it takes is a little massaging on the bottoms of the rockers where they come close to the springs/retainer its not that much really, that and you may need to use a lash cap. Thats all i did
