C-body brake plumbing question
#338219
06/04/09 06:42 PM
06/04/09 06:42 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
I am involved in engineering an awesome '65-'73 C-body lowbuck big disc brake swap. One "historical" fact, however, is just beyond my grasp: During the '65-'73 run of C-bodies, did the factory move the front hose frame bracket location, or was it constant?
If someone has a '65 and a '73 (even wrecks) and they are located identically, that info would really help (and will be passed along to the huddled masses). If the location did, in fact, change, any info re: where and when, would also be great appreciated.
Thanks,
Rick
Re: C-body brake plumbing question
[Re: Rick_Ehrenberg]
#338220
06/04/09 07:14 PM
06/04/09 07:14 PM
Posts: 52 CO
Twisted
CO
Rick, Disk and Drum brakes had different locations. I also believe that the Budd disks had a different location compared to the later disks. There is enough slack to relocate the bracket slightly when doing a conversion. Look on www.cbodydrydock.com there is a tech article for brake swaps with a lot of info on difference between the early/late systems.
Thank you Aaron
69 Dodge Polara 4DHT 70 Plymouth Duster 03 Dodge Neon R/T 05 Dodge Grand Caravan SXT
[Re: Andrewh]
#338226
06/05/09 08:38 PM
06/05/09 08:38 PM
Rick_Ehrenberg
Marlboro, NY, USA
From the 2 pix posted, they look close but "no cigar". I would not at all be surprised to see a year/year difference, but I would be floored if they were different disc/drum on the same year - sounds like a production plant nightmare!
What I will probably do is spec out a few different length hoses and advise the installer to do a mockup with a price of wire or vacuum tubing before buying the hoses, and do an update as the data comes in from you guys (which I TRULY appreciate).
Anybody planning a 65-73 C-cruiser disc swap, you're gonna love this! (and wait until you see our Auto-X 74-up C-bod in the issue that will hit the stands very soon!)
Thanks again,
Rick
#338227
06/06/09 06:45 PM
06/06/09 06:45 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Thanks again,
Rick
I can't wait to see if it's the truck/van spindle swap like I did...
[Re: 68FuryIIIColo]
#338231
08/05/09 02:37 AM
08/05/09 02:37 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
I did the 73 disk swap to my 68 Fury and used the original hard lines. I needed longer hoses so I used the ones from Russell's for a 70-72 Charger #694050. It even included the rear hose.
You can expect him to spill the beans right here. Or give someone else a head start into copying what he did and trying to compete against the product.
