AAR 340 valve lash #337945
06/04/09 09:12 AM
06/04/09 09:12 AM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
Hi,Do someone now the gab for valve lash ajustment ,in and out valve for a 340 six barrel?
cold or hot enegine?
Re: AAR 340 valve lash [Re: AAR70] #337946
06/04/09 09:29 AM
06/04/09 09:29 AM
Minnesota
3twos Offline
3twos  Offline
Minnesota
Al & Sheila
Re: AAR 340 valve lash [Re: 3twos] #337947
06/04/09 09:45 AM
06/04/09 09:45 AM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
My question is for solid camshaft and lifters
Re: AAR 340 valve lash [Re: AAR70] #337948
06/04/09 09:53 AM
06/04/09 09:53 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
that would depend on the cam and what the manufacturer wants dan
Re: AAR 340 valve lash [Re: ph23vo] #337949
06/04/09 06:36 PM
06/04/09 06:36 PM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
Use the cart to get it to the proper place in timing when you adjust the valves. Call or look up on line the lash for the cam you have. They will give you the lash. It will be around .015 for the intake and .018 for the exhaust on a cold engine. Set it tight. It is best to call and find out exactly from the manufacture of the cam.
Re: AAR 340 valve lash [Re: fastmark] #337950
06/05/09 06:06 AM
06/05/09 06:06 AM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
The motor is a TA 340 engine whit all stock.
U heads whit adjusteble rocker arms,stock solid lifter cam .
Lau
Re: AAR 340 valve lash [Re: AAR70] #337951
06/05/09 01:04 PM
06/05/09 01:04 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the stock aarcudas came with hydraulic cams but with adjustable rockers...
Tony
70 AARCuda Vitamin C
Re: AAR 340 valve lash [Re: 70AARcuda] #337952
06/07/09 05:39 AM
06/07/09 05:39 AM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
Okay...I thought AAR have solid lifter cam .I am wiser now ,thanks.
Lau.
Re: AAR 340 valve lash [Re: AAR70] #337953
06/07/09 08:08 AM
06/07/09 08:08 AM
19704406 Offline
19704406  Offline
A stock AAR engine valves are adjusted just like the 426 Hemi engine
