hemi hdy. roller springs #337930
06/04/09 08:26 AM
06/04/09 08:26 AM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
i asked this ? in the moparts qusetion & answer forum and haven't gotten a reply, so i'll ask here. what's the max seat pressure you should have on a valve spring with on a hemi hyd. roller cam? thanks, dave
Re: hemi hdy. roller springs [Re: 3ddart] #337931
06/04/09 11:23 AM
06/04/09 11:23 AM
I built a customer a new motor last summer,new World block, Mopar iron heads using a Comp Cams huydraulic roller cam and lifters and . I set the spring pressures at 175 lbs. or so on the seats and 375 to 390 over the nose. That was using Comp Springs, 10 degree retainers and keepers. Those pressures are the max that Comp said to run them at
Re: hemi hdy. roller springs [Re: 3ddart] #337932
06/04/09 11:38 AM
06/04/09 11:38 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
For my street Hemis that will never see 5500 RPM, using hydraulic roller cams I use the Comp #925 springs. These springs are 125 on the seat (at 1.9 installed height), and 340 over the nose at .550 lift. The valvetrain will last forever at these pressures.
