rubber stamp question and location? #337766
06/03/09 10:35 PM
06/03/09 10:35 PM
Ok, I don't know if it is a sickness or disease or what but I am addicted to details when it comes to restorations. You know, repro stampings, paint markings, repro decals, etc. I know the upper control arms had the part number rubber stamped onto the part somewhere. Does anyone know where the part number was stamped?
Second, I know that starting in 1969, they went to the square top rad tanks, starting with the 26" rads and then in 1970 with the smaller rads. I know the 26" rads had the "Made in Canada" yellow rubber stamp on the top of the tank. Did the smaller rads have this stamping also? If so, where abouts on the top of the rad tank?
This is for a 1970 Chally convert.
Thanks for all of your help with this.
Brian
Re: rubber stamp question and location? [Re: ] #337767
06/03/09 10:41 PM
06/03/09 10:41 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
Brian-The only time you will see a part number on the upper control arms will be an over the counter NOS replacement arm.As far as the Made in Canada stamp,I'm not sure on that one.I think it may be true on that part also.If I am wrong,I'm sure somebody will chime in.
Re: rubber stamp question and location? [Re: ] #337768
06/03/09 10:53 PM
06/03/09 10:53 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You sure assembly line upper control arms got P/N stamped on them? Usually over the counter NOS parts get inked stamped. Where as the assembly line does not. Or sometimes one part in a crate of parts gets a stamp or tag to identify the lot??
Do you have original untouched cars to show examples of UCA P/N stampings??
My 68 Barracuda has a white P/N stamp on inside of the drivers fender, but that is because it was replaced with a dealer part.
Glen Ray Radiators said there were at least a two different radicator vendors. At least one vendor had two different plants. I remember one was not in Canada.
Maybe Glen Ray Radiators can explain how to find the radiator vendor code. He is a Moparts member.
Re: rubber stamp question and location? [Re: autoxcuda] #337769
06/05/09 07:43 AM
06/05/09 07:43 AM
midwest
sg333e Offline
super street
sg333e  Offline
super street
midwest
I'm with the other guys. I've seen the photos of the Made in Canada bumper brackets, rads, etc. Looks cool but likely not correct for factory assembled car.
Hobbies and associated message boards: 1970 Cuda 440+6 FE5 H6X9 4 SP> Moparts.com 1987 Grand National (422rwhp/566tq)> TurboBuick.com 2008 BMW 335 TT 6MT> E90Post.com 2008 Gary Fisher HiFi Plus 29er > MTBR.com 2008 German Shorthair Pointer > Shorthairs.net
