Re: post your dual carb tunnel ram linkage setups...
[Re: toplescuda]
#337610
06/03/09 09:15 PM
06/03/09 09:15 PM
Posts: 437 south central pa
bdaz smblk
south central pa
I use the enderle linkage on mine and love it.all the moving parts ride in needle bearings or spherical rod ends so there is no binding. works great.Lukovich performance parts carries it.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: bdaz smblk]
#337611
06/03/09 09:37 PM
06/03/09 09:37 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Homemade linkage here, i didnt want to give $300-400 for a linkage kit just to modify it to fit my application. Which didnt involve the overly expensive Factory odd cross ram carbs. This linkage cost me less than $50 to make. Which consisted of old pieces of scrap 1/4 aluminum motor plate, and 3/8 aluminum round stock I drilled and tapped for 1/4" threads. This setup is super light too.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#337612
06/03/09 09:55 PM
06/03/09 09:55 PM
Posts: 8,889 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
yeah im gonna use rod ends easy to fab up just looking how you guys set ups were maybe give me a ideal or if i see something i like better then what im gonna make so far will have a bar that will run parlel (sp?) with the tunnel ram and it wil have a peice that will slide on then clamp to that rod and then a pair of rods that will go from that up to the carbs prob. some type of cable that will atach all of this to the throttle cable i know it sounds like [Edited by Moparts - Keep it clean]?? lol but it will work unless i see a set up i like better or eiser to fab up
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#337613
06/04/09 08:16 PM
06/04/09 08:16 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
anyone else??  come on guys your slacking lol
[Re: PlumCrazyCharger]
#337618
06/04/09 11:26 PM
06/04/09 11:26 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
so far thats pretty much what i have been fabbing up id like to see a little better detail on how went from down bar to connect to throtle cable so perhaps i can try to fig out a way to mount the kickdown
