Re: Holley Street avenger - Vacuum secondaries not opening
[Re: Crocker]
#336516
06/02/09 07:14 PM
06/02/09 07:14 PM
Posts: 3,905 Minnesota
3twos
Minnesota
Hey Glenn, did you check to make sure the secondary plates are not binding? Open the primaries all the way and then check to make sure the secondaries open freely and are not stuck. The vacumn diaphragm has a cork gasket between it and the carb, it's in the port between the two close together mounting screws that hold the diaphragm chamber to the carb. If you have an electric choke you need to remove it to get the vacumn chamber off.
Al & Sheila
[Re: 3twos]
#336520
06/03/09 12:14 PM
06/03/09 12:14 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Another thought is maybe that pasage isnt fully drilled? On that engine it's a small carb, and it should almost fall open...
[Re: Crocker]
#336525
06/04/09 10:32 PM
06/04/09 10:32 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Placing the diagram in the vacuum pot takes extra care. Any leak and it's not going to open.
[Re: Magnum]
#336526
06/05/09 11:51 AM
06/05/09 11:51 AM
moper
Columbia, CT
I have also heard of the small fiber O ring betweent he vacuum dashpot and the main throttle body not being placed properly on them. Still one of my top choices for carbs. It's not the design, it's the execution, and Holley is still overall one of the best "out of the box" places.
[Re: Crocker]
#336529
08/16/09 09:45 AM
08/16/09 09:45 AM
Hi Glenn, first: my english is not the best...but my heart beats mopar I have the same problem with the sec. My engine is a 383cui, with a weiand dual plane and first with a standard 600 Holley. All the basics are o.k. But the sec. will not open. (I have 2 Micro-switchs on the sec. to see on 2 LED's on the dash what's going on) If I open the primarys and blast a little air thruogh it the sec. opening very easy. (with the white spring) The same play with a 625 Road Demon and a 650 Speed Demon VE. If I drive a Kickdown from 3rd to first the sec. open 30% but not if I drive all gears manual until 5500rpm with throttle full open. What the hell is the problem ?? Have you find a solution until now ? Greetings from Germany Mario
[Re: Crocker]
#336530
08/16/09 11:14 AM
08/16/09 11:14 AM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
It's a 870 street avenger. I have went all the way to the weakest spring and they still don't seem to be opening. I tied the secondaries closed.... no perceptible difference in the power... Any suggestions? It's a 472 alum headed hemi with the M/P dual plane manifold- Comp 292 hemi cam. Thanks Glenn
Hey Glen, Was the V.S. carb for gas milage? I just don't read about 472 aluminum headed Hemis with V.S. carbs. It should work, you might have to talk to the guy's a Davinci carbs. I've had good advice from them years past about tuning V.S. carbs. Like everyone else is saying, Throw on an 850 D.P. for the fun high HP you want, then toss on the V.S. carb for the gas milage cruise.
Snap your neck, mega G-force launch, is all I want!
