1963 Dodge 572 update #336100
06/02/09 09:58 AM
06/02/09 09:58 AM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
Hi Guys any help would be appreciated.
After a dozen or so passes down the 1/4 mile track in the 3500 lb 63 Dodge the best et 9.92 best mph 135.34.
engine peak hp @ 6800 rpm shifting @ 6800 rpm crossing the finish line at 7350.
We are planning on running the car this weekend for a 2 day event. should I be to concerned with the RPM at the finish line? I don't want to hurt the engine! We are planning on changing the rear gears to 4.10's or 4.30's {what would you suggest}.
Could the gears be changed at the track if I went prepared? I have a mechanic who would help with the setting up of the gears but don't want to start something that we can't finish. The rear axle is a Dana 60.
I am also trying to tune a top end miss from the engine, once in hi gear the engine seems to struggle and doesn't gain rpm as fast as the 1 to 2 shift. fuel pressure @ 7.5 1150 jetted to 96 squared. timing @ 35.
thanks for any input.
Re: 1963 Dodge 572 update [Re: Rodney] #336101
06/02/09 11:39 AM
06/02/09 11:39 AM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
should have included:
rear tire size 32 inch tall
torque flight transmission.
Re: 1963 Dodge 572 update [Re: Rodney] #336102
06/02/09 11:51 AM
06/02/09 11:51 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Changing gears in a Dana at the track is NOT for the weak of heart. The whole rear end must come out.
Re: 1963 Dodge 572 update [Re: Rodney] #336103
06/02/09 11:56 AM
06/02/09 11:56 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
If there are no power valves in the carb, I would try jetting up two steps at a time see if the miss goes away and you pick up mph
Re: 1963 Dodge 572 update [Re: B1MAXX] #336104
06/02/09 12:19 PM
06/02/09 12:19 PM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
yes no power valves.
will do!
I have a set of 98's I'm just amazed it needs so much fuel, those jets are huge.
the plugs by no means look to rich so this may be the answer.
thanks
Re: 1963 Dodge 572 update [Re: Rodney] #336105
06/02/09 01:13 PM
06/02/09 01:13 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
572 at 3500 lbs with you in it? Of course it will turn less rpms with a 4.10 gear,but what are you 1/8 mile times and mph? How much conv slip? Have you tried less timming,shorter shift? What heads are on the car and headers what size?What brakes do you have? I would look at the 1/8 mile mph vs the 1/4 and see how much steam its making after the 1/8 before I chaged the gear.
Re: 1963 Dodge 572 update [Re: cudabunch] #336106
06/02/09 01:26 PM
06/02/09 01:26 PM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
yes 3500 lbs ready to race
Indy 440-1 reworked to flow 426
brakes Wilwood dual master cyl. 4 wheel disc.
1/8 108 mph 6.80's if I remember Dang left the time slips at the track with the car.
60 ft 1.45's and less only saw a couple in the 1.30's on a good air day.
launch the car @ 4200 shift will try and drop the shift RPM That may help thanks
Re: 1963 Dodge 572 update [Re: Rodney] #336107
06/02/09 01:38 PM
06/02/09 01:38 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Well there is the problem 6.80 @108 isnt fast enough. All the speed is comming from 3rd gear,so I would see what I could do about a better 60 foot and 1/8 mile time and MPH. again I would try less timming and a shorter shift to see what it does.
Re: 1963 Dodge 572 update [Re: cudabunch] #336108
06/02/09 02:00 PM
06/02/09 02:00 PM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
will do!
will be at the Fire and thunder race in woodburn this weekend.
the track and weather conditions were bad last weekend
hopefully for this big event the track will be prepped better.
Can't do much about the poor air
thanks
Re: 1963 Dodge 572 update [Re: Rodney] #336109
06/02/09 05:35 PM
06/02/09 05:35 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would try more timing and 7200 shift points. You always shift past the peak to get the best overall HP.
What gear do you have now??
1.3 shorts and 9.92 you sure your 1/8 mile was not 6.3???
Re: 1963 Dodge 572 update [Re: Dodgem] #336110
06/02/09 09:18 PM
06/02/09 09:18 PM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
4.56 gear now
decided on 4.30's will have them changed next Monday.
Re: 1963 Dodge 572 update [Re: Dodgem] #336111
06/02/09 09:58 PM
06/02/09 09:58 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I agree, there's something wrong there if it is 6.80.
Re: 1963 Dodge 572 update [Re: ProSport] #336112
06/02/09 10:02 PM
06/02/09 10:02 PM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
ok I screwed up the 1/8 mile are closer to 6.40's best 6.38
I'm horrible at remembering numbers
