Page 2 of 3 1 2 3
Re: Any 400 builds here? (non stroker) [Re: 440newport] #335972
06/02/09 10:46 PM
06/02/09 10:46 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
I built one last summer.It was a low milage core.Used the stock cast pistons and stock cast crank.Put a set of max wedge heads on it that was cut all to hell.Put one of my roller cams in it,cam was a NOS grind so it had a wide lobe on it.With 1.6 rockers was 620/640.This has been a heck of a motor.On the spray it ran 6.40s in my wagon.I have hit it with a 200 shot for a year now.
Re: Any 400 builds here? (non stroker) [Re: 8secDart] #335973
06/02/09 11:20 PM
06/02/09 11:20 PM
I built one last summer.Used the stock cast pistons I have hit it with a 200 shot for a year now.
Mopar cast pistons are actually very stout. I would like to use the later 75 & up 400 cast piston w a 440 crank if the dimentions would make for good quench but I believe that it would need valve notches to be cut.
Re: Any 400 builds here? (non stroker) [Re: RapidRobert] #335974
06/02/09 11:38 PM
06/02/09 11:38 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I thought if you ran 440 pistons in a 400 you needed to cut valve notches into the pistons? Seems clearance would get mighty tight with that tall of a piston and no notches...?
Re: Any 400 builds here? (non stroker) [Re: DaytonaTurbo] #335975
06/02/09 11:46 PM
06/02/09 11:46 PM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
There might be another way. You could turn the pin to 2.2" use a 6.8" rod and either a 1.480"cd or 1.485"cd piston.
Randy
Re: Any 400 builds here? (non stroker) [Re: DaytonaTurbo] #335976
06/02/09 11:48 PM
06/02/09 11:48 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Possibly, but lots of guys run the the flattop TRW's in 440's and 383's that are only slightly down in the hole (or zero deck with a light cut) and they seem to run fine?
Re: Any 400 builds here? (non stroker) [Re: 440newport] #335977
06/03/09 12:14 AM
06/03/09 12:14 AM
Manitoba, Canada
Manitoba, Canada
I always figured the factory didn't put valve reliefs in the 440 6-pack pistons just for fun...?
Re: Any 400 builds here? (non stroker) [Re: DusterKrazy] #335978
06/03/09 01:25 AM
06/03/09 01:25 AM
AndyF Online content
AndyF  Online Content
I did this one a few years ago. 400 with a 383 forged crank, Hemi rods and 451 pistons. With lightly ported Edelbrock heads and a decent roller cam it makes 600 hp. Made for a slightly radical A body car that my buddy drove to the track and back.
Re: Any 400 builds here? (non stroker) [Re: AndyF] #335979
06/03/09 06:34 AM
06/03/09 06:34 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
this was the one I was thinking of, but couldn't find the thread in the search function. andy, did you ever write a magazine article on this one?
2017 Grand Cherokee Overland
Re: Any 400 builds here? (non stroker) [Re: RemCharger] #335980
06/03/09 09:47 AM
06/03/09 09:47 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Looking at cams to maximize low end torque as well..
Turning an apple into an orange?
exactly , a single plane intake is NOT the best intake for LOW END TORQUE ...
this build is all over the place ...
now I'll jump on the band wagon , you have to build a stroker
Re: Any 400 builds here? (non stroker) [Re: 440newport] #335981
06/03/09 09:50 AM
06/03/09 09:50 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
And what TRW/speedpro piston in a 440 would that be ? The only pistons available are either .020 in the hole , the 6pk piston and it has valve reliefs or the low compression pistons and the closet one to the deck is .100 in the hole ?????
as far as the 383 , the flattop is .015 in the hole , anything else is deeper or have a valve CANYON ...
Re: Any 400 builds here? (non stroker) [Re: JohnRR] #335982
06/03/09 10:44 AM
06/03/09 10:44 AM
440newport Offline
440newport  Offline
Yeah that KB 383 piston is pretty much a canyon I thought the 440 piston came closer to the deck than .020.
At deck height spec the F-M 424 440 piston should be roughly .010 in the hole in a 400. I'm wondering could you get away with a flattop 0 deck piston in a 400 without valve reliefs with say a cam of about .500 lift?
Re: Any 400 builds here? (non stroker) [Re: JohnRR] #335983
06/03/09 02:01 PM
06/03/09 02:01 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
I know single planes are not heavy torque makers, but would the engine really know the difference
if I added a 1 inch aluminum 4 hole spacer???
I have to use whats available and what I can get
cheap..
Re: Any 400 builds here? (non stroker) [Re: DusterKrazy] #335984
06/03/09 02:15 PM
06/03/09 02:15 PM
IL
furious70 Offline
furious70  Offline
IL
A stock 383 HP intake would probably be better than that Weiand (Team G?) single plane if you're worried about low end tq. Best bet would be a used rpm perf. Even an old torker or tm6 didn't do too bad down low in Hot Rod's b engine intake test.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Any 400 builds here? (non stroker) [Re: furious70] #335985
06/03/09 02:40 PM
06/03/09 02:40 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
It's a old school weiand 7511 and it looks similar to an eddy torker.
Re: Any 400 builds here? (non stroker) [Re: DusterKrazy] #335986
06/03/09 02:55 PM
06/03/09 02:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
don't matter , adding a spacer is not going to restore your bottom end .
Re: Any 400 builds here? (non stroker) [Re: JohnRR] #335987
06/03/09 03:08 PM
06/03/09 03:08 PM
IL
furious70 Offline
furious70  Offline
IL
based on my own use of one on an 383HP in a street car and the Hot Rod test, stay away from the Holley Street Dominator intake for sure if you want low end grunt. Don't know anything about that old Weiand.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Any 400 builds here? (non stroker) [Re: JohnRR] #335988
06/03/09 03:10 PM
06/03/09 03:10 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
Im gonna try it and worse comes to worse I'll get another intake. I have an offy on my small block and from what moparts members say it's a crap intake. I disagree, it pulls like a freight train!
Re: Any 400 builds here? (non stroker) [Re: DusterKrazy] #335989
06/03/09 03:24 PM
06/03/09 03:24 PM
IL
furious70 Offline
furious70  Offline
IL
dynos don't lie. Don't know about the sb one, but the offy intakes in the b engine test were downright terrible in comparison to the best in class ones.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Any 400 builds here? (non stroker) [Re: DusterKrazy] #335990
06/03/09 03:30 PM
06/03/09 03:30 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Those X-cellerator intakes are very poor performers. I have one. Tried it on my 383, and its sat on the bench every since. Any edelbrock will far out perform it.
Re: Any 400 builds here? (non stroker) [Re: AndyF] #335991
06/03/09 03:53 PM
06/03/09 03:53 PM
California
court9155 Offline
court9155  Offline
California
What kind of machining was involved? What 451 pistons?
I already have the 400 block and forged 383 crank please advise!!
Dan
67 charger
Page 2 of 3 1 2 3
