the green bombers new dyno results. #335950
06/02/09 12:09 AM
06/02/09 12:09 AM
houston texas
gremlinsteve Offline OP
houston texas
dynojet chasis dyno. this is a 3rd gen 5.7 liter based stroker. now has 392 cid up from the stock 345.
same head as before with a port match to a 6.1 hemi intake. (not liking that swap btw...kills low end torque too much in my opinion).
3.937 bore off a 4.050 stroke. 2.02 intake and a 1.57 exhaust valve.
cam specs out at 235/247 on the @50 number. .585 lift
will try to post up a sound clip later. same motor earlier this year on a bit less cam made 447 rwhp and 487 torque and madea 11.53 pass...hoping to pick that up a few tenths
steve-o
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: the green bombers new dyno results. [Re: gremlinsteve] #335951
06/02/09 12:12 AM
06/02/09 12:12 AM
houston texas
houston texas
also...we run it off a 18 percent dt loss if any one is interested. with that, your looking at about 560 at the crank.
steve
