Re: Troubleshoot Power Brake Booster
[Re: 69rrconvert]
#335679
06/02/09 10:24 AM
06/02/09 10:24 AM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
Booster Dewey rebuilds them in Portland OR. http://boosterdeweyexchange.com/There have been posts on here before that speak very highly of his services. Mine is there right now, and will post pics when I get it back.
[Re: wkroncke17]
#335680
06/02/09 10:32 AM
06/02/09 10:32 AM
Posts: 15,491 the boonies
aarcuda
the boonies
Booster Dewey rebuilds them in Portland OR. http://boosterdeweyexchange.com/ There have been posts on here before that speak very highly of his services. Mine is there right now, and will post pics when I get it back.
he did mine and i am very very happy with the results
[Re: Crizila]
#335683
06/02/09 02:07 PM
06/02/09 02:07 PM
Posts: 6,516 Santa Cruz, California
Lefty
How do you troubleshoot a power brake booster? My 69 rr convert has been converted to front disc brakes using 73 A body components. Since this conversion, the brake pedal is hard and I have to stand on it to stop the car. I suspect the power booster but am unsure how to troubleshoot it. Any ideas?? Thanks in advance
Easiest check to see if the booster is working: With the engine off, put moderate pressure on the brake pedal. Then start the car. Pedal should drop about 1-2 inches.
[Re: 69rrconvert]
#335685
06/02/09 08:37 PM
06/02/09 08:37 PM
Posts: 7,506 Az
Crizila
Az
About 70% of the braking is done by the front brakes, and since your problem started when you converted over to disc, I would guess that you have a component mismatch ether in the booster ( too small - although working ) or master cyl. RU using a porportioning valve and is it adjustable?
Fastest 300
