Wounded bullet, KB block q's
#335003
06/01/09 06:34 AM
06/01/09 06:34 AM
Posts: 2,926 A shed in England
Tig
A shed in England
Well I hurt the motor over the weekend . 1st impressions are a damaged or holed piston. I'm wondering how much of an over bore can a 4.50 KB sleeve take? Since I know KB isn't really doing buisness anymore are replacement sleeves available?. I know some of you guys run 588ci's on Indy and KB blocks so is that a 4.560 bore with the standard 4.800 bore spacing or more stroke? Thanks in advance. Tig
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: Wounded bullet, KB block q's
[Re: dthemi]
#335006
06/01/09 07:07 AM
06/01/09 07:07 AM
Tig
A shed in England
Thanks for the reply Darren, that opens up my options a bit. Are you @ 4.800 bore spacing?
[Re: Tig]
#335007
06/01/09 07:48 AM
06/01/09 07:48 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Mine is 4.500" bore. Ken Black told me it would go to 4.530". It may be fine to go bigger than that, but I'm not sure. CHIP
Post deleted by Defbob
[Re: an8sec70cuda]
#335008
06/01/09 09:20 AM
06/01/09 09:20 AM
[Re: dthemi]
#335010
06/01/09 12:05 PM
06/01/09 12:05 PM
Tig
A shed in England
Just taken the head off, looks like the piston has just broken up. I think I posted a pic of a piston not so long ago where there was signs of detonation. This is the same #1 Piston and it has broke in the exact same place. Combustion sigs on the chambers look spot on (except #1 of course). Looks like the previous lot of detonation has damaged the integrity of the piston and it has just let go Note the nice even carbon covering on no 3 chamber, no detonation there. Ouch!!!! Note the distortion on the fire ring. Remember this, the red felt pen mark is where the damage was.
[Re: Tig]
#335011
06/01/09 03:17 PM
06/01/09 03:17 PM
Posts: 1,106 Quebec, Canada
Diablo
Quebec, Canada
Call Darton sleeve. Thye will make you what you want. http://www.dartonsleeves.com/I had a set of sleeves made for my engine (4.562bore) in a KB stage 7 block. but its a 4.840BS block. Really nice sleeves
