Coilover Brackets? #334942
05/31/09 11:27 PM
05/31/09 11:27 PM
NC
DARTSPORT340 Offline OP
super gas
super gas
NC
Ok I've got a question about upper coilover mounts. Mine (see attach) are mounted on the frame but I have talked to two people that say I should move them to their own seperate crossmember but niether could tell me why. Will it work the way it is or do I need to change it?
Re: Coilover Brackets? [Re: DARTSPORT340] #334943
05/31/09 11:34 PM
05/31/09 11:34 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
mine are on frame too & mine work ok.
Re: Coilover Brackets? [Re: rebel] #334944
05/31/09 11:46 PM
05/31/09 11:46 PM
NC
super gas
super gas
NC
I figured it would be ok but im no chassis guy so I wanted to ask. Both the guys that told me they needed to be moved couldnt give me reason why thay just said it need to be that way.
Re: Coilover Brackets? [Re: rebel] #334945
05/31/09 11:46 PM
05/31/09 11:46 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Attachment not working.
Re: Coilover Brackets? [Re: rowin4] #334946
05/31/09 11:47 PM
05/31/09 11:47 PM
Pennsylvania
proshiftcharger Offline
Pennsylvania
Correct, it's not working.
Re: Coilover Brackets? [Re: proshiftcharger] #334947
05/31/09 11:58 PM
05/31/09 11:58 PM
NC
super gas
super gas
NC
Hmmm let me just post a pic.....
Re: Coilover Brackets? [Re: DARTSPORT340] #334948
06/01/09 12:08 AM
06/01/09 12:08 AM
rowin4 Offline
rowin4  Offline
Now we can see what your asking about. When i put in my ladder bar/coil over set up i called competition engineering and asked about shock placement and angles, the guy said to get the shocks as straight up as possible for best results. Mounting off the frame isn't your problem its the angle of the shocks, but that's just what i was told and seamed to make since to me.
Re: Coilover Brackets? [Re: rowin4] #334949
06/01/09 12:13 AM
06/01/09 12:13 AM
Northeast, Arkansas
Dodgeman67 Offline
Dodgeman67  Offline
Northeast, Arkansas
If it was mine I would just put two tabs on each side of the upper shock mount and weld the tabs to the frame and put a bolt through it all and it would be like being on the cross member only turned opposite from the way they are now.
Re: Coilover Brackets? [Re: Dodgeman67] #334950
06/01/09 12:27 AM
06/01/09 12:27 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
I see what you need. Something you now need to consider is that the upper and lower shock mounts are also your suspension mounts. Meaning it has to support the weight of the car as well as be a means of dampening it movements thru your shocks. If the mounts are not rigid enough for the weight of the car in a dynamic situation as in launching the car, how can they be an effective tuning point with your shocks and springs. The shocks should be as verticle as possible and the mounts need to be sturdy. If it were mine, I would look at what your buddy told you. For as little work as it would take, you could eliminate any chance of the upper mount flexing. It looks like it is a stud off the frame rail which would give it place to flex by design. Hope this helps. Beep
Re: Coilover Brackets? [Re: Bigbeep] #334951
06/01/09 12:30 AM
06/01/09 12:30 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Something else. Tell me you are still building. I don't see any brakes! Beep
Re: Coilover Brackets? [Re: DARTSPORT340] #334952
06/01/09 12:45 AM
06/01/09 12:45 AM
Pennsylvania
Pennsylvania
I would consider moving the upper shock mounts outwards. By doing this you will achieve two things...
1) It will get your shocks more verticle.
2) If done right using a tab design you will increase your strength. It will be less likely to break, or flex like the stud mounts you currently have.
