How much fuel for a 420" 700 HP SB on race gas? #334862
05/31/09 10:30 PM
05/31/09 10:30 PM
Huron, South Dakota, United St...
dustyhof Offline OP
dustyhof  Offline OP
My buddy's mechanical Race Pump died today with only 5 runs and less than 20 street miles on it. He's going to hook up his Holley blue pump so he can take it to a car show this weekend, but we don't think it will be enough fuel to feed the Valiant. He wanted the mechanical because he hated the ultra loud whine of the Holley pump. I have Mallory Comp 140's on my cars and they are much quieter. I was thinking he needed at least a Mallory Comp 250, or would the 140 be enough? What other ones are fairly quiet? Thanks.
Re: How much fuel for a 420" 700 HP SB on race gas? [Re: dustyhof] #334863
05/31/09 11:33 PM
05/31/09 11:33 PM
dustyhof Offline OP
dustyhof  Offline OP
Nobody?
Re: How much fuel for a 420" 700 HP SB on race gas? [Re: dustyhof] #334864
05/31/09 11:35 PM
05/31/09 11:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If he keeps the RPM down the blue will work fine
Re: How much fuel for a 420" 700 HP SB on race gas? [Re: MR_P_BODY] #334865
05/31/09 11:48 PM
05/31/09 11:48 PM
dustyhof Offline OP
dustyhof  Offline OP
He shifts about 7200-7500?
Re: How much fuel for a 420" 700 HP SB on race gas? [Re: dustyhof] #334866
06/01/09 12:22 AM
06/01/09 12:22 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
That green thing made it to the track yet??? The lil blue duster is still sitting waiting for it's Dr Diff Dana 60 to arrive.
Re: How much fuel for a 420" 700 HP SB on race gas? [Re: J_BODY] #334867
06/01/09 06:06 PM
06/01/09 06:06 PM
dustyhof Offline OP
dustyhof  Offline OP
Yep. Last weekend. Vaccuum pump was pulling a lot of oil out of the motor until he switched valve covers around. Spinning pretty bad at the launch. It made 5 passes with a best of 10.33 @ 131 footbraking, spinning, and 30 degrees timing. It's got a lot left in it yet. He's thinking the rear springs are too stiff. He's going to get it scaled and put some lighter springs in it to get it to plant the tire a little harder? Garber helped him a little at the track. We don't know much about suspension set up.
Re: How much fuel for a 420" 700 HP SB on race gas? [Re: dustyhof] #334868
06/01/09 07:28 PM
06/01/09 07:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The 140 MIGHT make it but would be better with a
larger pump. I was thinking he wanted to hit a show
or something like that... with a temporary pump, thats
why I said keep the revs down
Re: How much fuel for a 420" 700 HP SB on race gas? [Re: MR_P_BODY] #334869
06/01/09 10:14 PM
06/01/09 10:14 PM
dustyhof Offline OP
dustyhof  Offline OP
Ok. Thanks Mike. He's just going to put his Holley blue on for the show. We know it will work for that. He won't be racing with that pump. Too small and makes to much noise. Temporary fix. I was just wanting to figure out a permanent solution. I think I will steer him towards the Mallory Comp 250. He's also toying with the idea of going to E-85. I wonder what the difference is between the standard Comp 250 & the alcohol version? Besides more money. Could you run race gas through the alcohol one until you switched?
Re: How much fuel for a 420" 700 HP SB on race gas? [Re: dustyhof] #334870
06/01/09 10:17 PM
06/01/09 10:17 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
don't hold me to this but i "think" the difference between the alky and gas pumps is only the seal and possibly gaskets. personally i think the comp 250 is one of the best electric pumps out there.
Re: How much fuel for a 420" 700 HP SB on race gas? [Re: dustyhof] #334871
06/01/09 10:35 PM
06/01/09 10:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You dont need a alky pump for E-85, a standard pump
that will support 30% more volume than gas will work
Re: How much fuel for a 420" 700 HP SB on race gas? [Re: MR_P_BODY] #334872
06/01/09 11:03 PM
06/01/09 11:03 PM
dustyhof Offline OP
dustyhof  Offline OP
Ok. Thanks!
Re: How much fuel for a 420" 700 HP SB on race gas? [Re: MR_P_BODY] #334873
06/02/09 10:21 PM
06/02/09 10:21 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
What do you think about e-85 availibility ? I read in the newspaper they were closing 3 plants here in Ohio? They were saying cost factors were more than gasoline?
Re: How much fuel for a 420" 700 HP SB on race gas? [Re: Lil Wedge] #334874
06/02/09 10:32 PM
06/02/09 10:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Here in Mich its still cheaper than regular and still
easy to get... I get mine at Meijer. Being that the
fuel prices are heading up again I think you will see
the push for it again. Its still MUCH cheaper than
race 110(by ALOT)
