71 Dart. #334489
05/31/09 06:46 PM
05/31/09 06:46 PM
Bethel Ct
AdamR Offline OP
AdamR  Offline OP
Bethel Ct
Thought I would share some pictures of my 71 Dart.
I bought the car pretty much disassembled in Dec 07. It finally saw paint last month.
Heres a picture from the day I brought it home.
[IMG]/IMG]
It was in a coat of 2K primer and had a new quarter on the passenger side. The last owner (member Moper) gave me pictures of all his work up till I bought it.
I decided the interior had to come out to do the jams right.
and while I had the tools out I may as well strip the rest down.
Someone decided an aftermarket sunroof was a good idea. I didnt really agree. Next time I'll replace the entire roof instead of patching it. It took for ever to get it straight.
Lots of blocking,
Taping
And finally color
I wanted a red with a lot of orange in it. I think I picked the right color which is hard to do with a 1X1" block in a book.
Back at home I cleaned up the wheel wells.
added a Bee stripe from ChallengerGary
And started bolting things together.
Next up is the motor. Its a mild 360, Ported 302 heads, 10:1 comp. XE268 cam. Im going to top it off with a stock 71 340 intake and a TQ. small tube heads and a 2.5" exhaust.
The car also came with big bolt disc brakes, 355 sure grip 8-3/4 and a 833 OD trans. It should make a great street car.
Re: 71 Dart. [Re: AdamR] #334490
05/31/09 07:10 PM
05/31/09 07:10 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
Wow, fantastic work. This car is beautiful...
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
Re: 71 Dart. [Re: sycboi] #334491
05/31/09 09:06 PM
05/31/09 09:06 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Gorgeous car! Nice work too!
Joe
65 Barracuda
70 Challenger
Re: 71 Dart. [Re: jrwoodjoe] #334492
06/01/09 03:10 PM
06/01/09 03:10 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Very nice work. Great color choice, too.
Re: 71 Dart. [Re: Fab64] #334493
06/01/09 04:43 PM
06/01/09 04:43 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Looks fantastic!
Re: 71 Dart. [Re: DusterKrazy] #334494
06/01/09 09:14 PM
06/01/09 09:14 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I love the 70-72 Darts and I really like them with the dual scoops and the stripe. And yours is an awesome looking one. Nice work. Ron
Re: 71 Dart. [Re: AdamR] #334495
06/02/09 12:33 PM
06/02/09 12:33 PM
ohio
70shaker6pk Offline
super gas
70shaker6pk  Offline
super gas
ohio
Very very nice!!!!!
Re: 71 Dart. [Re: 70shaker6pk] #334496
06/04/09 08:19 AM
06/04/09 08:19 AM
Bethel Ct
AdamR Offline OP
AdamR  Offline OP
Bethel Ct
Thanks guys !
Re: 71 Dart. [Re: AdamR] #334497
06/05/09 02:23 PM
06/05/09 02:23 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
great stuff, Adam!
Re: 71 Dart. [Re: sharpie] #334498
06/20/09 10:00 AM
06/20/09 10:00 AM
Bethel Ct
AdamR Offline OP
AdamR  Offline OP
Bethel Ct
Had some time to play with the car this week so I finished cleaning up the motor and dropped it in place. I used Plasticoat Hemi orange.
The motor is a mild 360 built by Moper. Its a 72 360 block that was remaned by Mopar in the 90s. Dave (Moper) added aComp Cams XE 268H and a set of 302 casting 318 heads that he added 1.88-160 valves to. I believe the ports are stock 318 size.
The heads were shaved a bit to get the compression up to 10:1. I had a stock 71 Thermoquad intake cut down a bit to replace the old Torker Dave was using on it.
I also scored a 72 340, Thermoquad off of ebay a few months ago for $75. The carb looks all most new. Even the plating on the linkage was still good.
The 340 air cleaner was another great score. $100 from a member. I cleaned it up and sprayed it with 2 heavy coats of EastWood wrinkle black. My first didnt work out well. The paint didnt wrinkle and was to shiny.
The second time I set time I heated the grill up to about 150* put down to heavy coats of paint with 3 minutes in between coats and set teh parts on the grill. Covered the grill and let it go for 15 minutes. This worked much better.
Thats the original sticker on the air cleaner that I taped off.
Im kinda stuck now. I cant decide what to do exhaust wise. Headers would probably be the best bet but they just wont look right with everything else looking so stock. I really want to run a set of 68-70 Hi-Po manifolds but at $400 or so a pair I just cant afford them right now.
I also cant find were I put the proportioning valve which needs to go in before the exhaust and clutch linkage. Ofcoarse I still need the brake line set for the car.
I started putting the tranny in but I'm missing 1 pressure plate bolt. I also cant find were I put the starter.
Re: 71 Dart. [Re: AdamR] #334499
06/20/09 04:11 PM
06/20/09 04:11 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Do a bit of a search, Adam. From what I recall, the Magnum manifolds flow close to the 340 units. I know they fit in the B and E-bodies alright. Just not sure about the A's. They should be alot cheaper and alot easier to find. Still have a stock feel to them, while netting you some decent performance.
My
2 Demons...no, not my kids!
Re: 71 Dart. [Re: 4speeds4me] #334500
06/20/09 04:30 PM
06/20/09 04:30 PM
Bethel Ct
AdamR Offline OP
AdamR  Offline OP
Bethel Ct
I dont believe they fit A bodies but I will look in to it.
Re: 71 Dart. [Re: AdamR] #334501
06/20/09 05:13 PM
06/20/09 05:13 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Engine bay looks great Adam. Very nice!
Re: 71 Dart. [Re: jrwoodjoe] #334502
06/20/09 05:54 PM
06/20/09 05:54 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
that is swet! and beat the bushes for your manifolds. I picked up a set at The Nats a few years ago for my Charger for $40 when everyone else wanted $250 and more.
1981 Dodge D150 360 auto
Re: 71 Dart. [Re: basketcase] #334503
06/22/09 10:36 AM
06/22/09 10:36 AM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
Unfortunately Adam is right - they won't fit a 71 A-Body, just early-As.
Re: 71 Dart. [Re: sharpie] #334504
06/22/09 11:32 AM
06/22/09 11:32 AM
4speeds4me Offline
4speeds4me  Offline
You're serious? The Magnum manifolds will fit in the smaller bay of the early A-bodies, and not the larger bay of the 67-on? Go figure. You kinda made my day if that's the case, as I've been trying to figure out what to use in my 64.
Re: 71 Dart. [Re: 4speeds4me] #334505
06/22/09 02:10 PM
06/22/09 02:10 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
i beleive there was a set of hi po manifolds for a 71 a body in minneapolis craigslist for $250? ill check later and find out. great looking car!
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: 71 Dart. [Re: 4speeds4me] #334506
06/22/09 02:33 PM
06/22/09 02:33 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
I don't believe the size is the issue, I believe it's where one of the sides dumps.
http://www.forabodiesonly.com/mopar/showthread.php?p=237240
Re: 71 Dart. [Re: sharpie] #334507
06/22/09 05:55 PM
06/22/09 05:55 PM
Bethel Ct
AdamR Offline OP
AdamR  Offline OP
Bethel Ct
Mopar 1, If I use manifolds they will be 68-70 style, The 71s went to a center dump on the passenger side.
4speeds, I believe the driver side Mag manifolds dumps in to the steering column.
Re: 71 Dart. [Re: AdamR] #334508
06/23/09 12:39 AM
06/23/09 12:39 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
alright, thought id help
1937 Plymouth PT50
