71 Dart.
#334489
05/31/09 06:46 PM
05/31/09 06:46 PM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
Thought I would share some pictures of my 71 Dart. I bought the car pretty much disassembled in Dec 07. It finally saw paint last month. Heres a picture from the day I brought it home. [IMG] /IMG] It was in a coat of 2K primer and had a new quarter on the passenger side. The last owner (member Moper) gave me pictures of all his work up till I bought it. I decided the interior had to come out to do the jams right. and while I had the tools out I may as well strip the rest down. Someone decided an aftermarket sunroof was a good idea. I didnt really agree. Next time I'll replace the entire roof instead of patching it. It took for ever to get it straight. Lots of blocking, Taping And finally color I wanted a red with a lot of orange in it. I think I picked the right color which is hard to do with a 1X1" block in a book. Back at home I cleaned up the wheel wells. added a Bee stripe from ChallengerGary And started bolting things together. Next up is the motor. Its a mild 360, Ported 302 heads, 10:1 comp. XE268 cam. Im going to top it off with a stock 71 340 intake and a TQ. small tube heads and a 2.5" exhaust. The car also came with big bolt disc brakes, 355 sure grip 8-3/4 and a 833 OD trans. It should make a great street car.
Re: 71 Dart.
[Re: AdamR]
#334490
05/31/09 07:10 PM
05/31/09 07:10 PM
Posts: 990 Norwalk, Ohio
sycboi
Norwalk, Ohio
Wow, fantastic work. This car is beautiful...
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
Re: 71 Dart.
[Re: sycboi]
#334491
05/31/09 09:06 PM
05/31/09 09:06 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Gorgeous car! Nice work too! Joe
65 Barracuda 70 Challenger
Re: 71 Dart.
[Re: AdamR]
#334497
06/05/09 02:23 PM
06/05/09 02:23 PM
Posts: 5,037 hi
sharpie
Moparts Linguist
Moparts Linguist
hi
Re: 71 Dart.
[Re: sharpie]
#334498
06/20/09 10:00 AM
06/20/09 10:00 AM
AdamR
Bethel Ct
Had some time to play with the car this week so I finished cleaning up the motor and dropped it in place. I used Plasticoat Hemi orange. The motor is a mild 360 built by Moper. Its a 72 360 block that was remaned by Mopar in the 90s. Dave (Moper) added aComp Cams XE 268H and a set of 302 casting 318 heads that he added 1.88-160 valves to. I believe the ports are stock 318 size. The heads were shaved a bit to get the compression up to 10:1. I had a stock 71 Thermoquad intake cut down a bit to replace the old Torker Dave was using on it. I also scored a 72 340, Thermoquad off of ebay a few months ago for $75. The carb looks all most new. Even the plating on the linkage was still good. The 340 air cleaner was another great score. $100 from a member. I cleaned it up and sprayed it with 2 heavy coats of EastWood wrinkle black. My first didnt work out well. The paint didnt wrinkle and was to shiny. The second time I set time I heated the grill up to about 150* put down to heavy coats of paint with 3 minutes in between coats and set teh parts on the grill. Covered the grill and let it go for 15 minutes. This worked much better. Thats the original sticker on the air cleaner that I taped off. Im kinda stuck now. I cant decide what to do exhaust wise. Headers would probably be the best bet but they just wont look right with everything else looking so stock. I really want to run a set of 68-70 Hi-Po manifolds but at $400 or so a pair I just cant afford them right now. I also cant find were I put the proportioning valve which needs to go in before the exhaust and clutch linkage. Ofcoarse I still need the brake line set for the car. I started putting the tranny in but I'm missing 1 pressure plate bolt. I also cant find were I put the starter.
Re: 71 Dart.
[Re: AdamR]
#334499
06/20/09 04:11 PM
06/20/09 04:11 PM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
Do a bit of a search, Adam. From what I recall, the Magnum manifolds flow close to the 340 units. I know they fit in the B and E-bodies alright. Just not sure about the A's. They should be alot cheaper and alot easier to find. Still have a stock feel to them, while netting you some decent performance. My
2 Demons...no, not my kids!
Re: 71 Dart.
[Re: jrwoodjoe]
#334502
06/20/09 05:54 PM
06/20/09 05:54 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
that is swet! and beat the bushes for your manifolds. I picked up a set at The Nats a few years ago for my Charger for $40 when everyone else wanted $250 and more.
1981 Dodge D150 360 auto
Re: 71 Dart.
[Re: sharpie]
#334504
06/22/09 11:32 AM
06/22/09 11:32 AM
4speeds4me
Unfortunately Adam is right - they won't fit a 71 A-Body, just early-As.
You're serious? The Magnum manifolds will fit in the smaller bay of the early A-bodies, and not the larger bay of the 67-on? Go figure. You kinda made my day if that's the case, as I've been trying to figure out what to use in my 64.
Re: 71 Dart.
[Re: 4speeds4me]
#334505
06/22/09 02:10 PM
06/22/09 02:10 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
i beleive there was a set of hi po manifolds for a 71 a body in minneapolis craigslist for $250? ill check later and find out. great looking car!
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
Re: 71 Dart.
[Re: 4speeds4me]
#334506
06/22/09 02:33 PM
06/22/09 02:33 PM
Posts: 5,037 hi
sharpie
Moparts Linguist
Moparts Linguist
hi
I don't believe the size is the issue, I believe it's where one of the sides dumps.
http://www.forabodiesonly.com/mopar/showthread.php?p=237240
