long distance troubleshooting #334452
05/31/09 05:00 PM
05/31/09 05:00 PM
Garry Owen Offline OP
I can't go out and look at it so...
I think I burnt a valve but maybe someone has seen it before. The carb started dumping fuel and I'm pretty sure it wasn't for but a day or two until I caught it. It did belch and throw some fire(and stayed on fire) so I went and got a new carb. I got it home with alot of surging and almost no power. Now it wont start without spitting flames and dies. The day I left I got it to fire and stayed running, but rough, at idle for about 5 minutes.
I was going to take it to a shop on my mid-tour leave, but decided I would do it myself and If I can get a guesstimation on what it might be I can arrange someone to accept whatever work I might need done during that time.
Without tearing it apart I was guessing a valve but I keep wondering about timing also, any thoughts?
Re: long distance troubleshooting [Re: Garry Owen] #334453
05/31/09 06:09 PM
05/31/09 06:09 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Do a compression test and record your numbers if you burnt a valve you'll find it.
Re: long distance troubleshooting [Re: Garry Owen] #334454
05/31/09 06:36 PM
05/31/09 06:36 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
without more info hard to say,
Maybe a broken rocker, bent pushrod???
Samll block, big block, history on the motor????
Re: long distance troubleshooting [Re: TJP] #334455
05/31/09 06:44 PM
05/31/09 06:44 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
timing chain age?
Re: long distance troubleshooting [Re: RodStRace] #334456
05/31/09 07:43 PM
05/31/09 07:43 PM
Sorry guys I know it's about as vague as it gets. I just wanted to start buying parts now but in reality I need to buy everything for the heads anyways for a refresh and a new timing chain isn't going to hurt.
