Line lock and 4 speed cars
#334344
05/31/09 02:53 PM
05/31/09 02:53 PM
Posts: 576 Somewhere Over the Hill
Mr. Dodge
I have a question....
I have a 4-speed in my car and i have access to a micro switch, I had a thought that involves that micro switch..... Has anyone here used a micro switch on the clutch peddle to disengage the line lock went your is staged? If so, How did you install it and was there any problems or is this even feasible?
"The advantage of being armed the Americans possess over the people of all other nations,which are carried as far as the public resources will bear, the governments are afraid to trust the people with arms."(James Madison)
69 Hemi Coronet R/T
70 456 Dart Swinger
Re: Line lock and 4 speed cars
[Re: Mr. Dodge]
#334345
05/31/09 04:46 PM
05/31/09 04:46 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
you gotta remember that the line lock blocks fluid in both directions.. so if you apply the clutch at speed and have to apply the brakes you will not have front brakes if the clutch pedal activates the line lock at speed.. maybe through adjustment and a brake light switch applied to the clutch and another inline switch the completes the circuit when in first gear or something...that might work..? or a button that is on the steering wheel that completes the circuit...the clutch pedal still activates the selinoid but the button has to be pressed to complete the circuit.. after launch just release the button then when you apply the clutch it wont re-activate.. cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: dvw]
#334349
05/31/09 06:42 PM
05/31/09 06:42 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
The line lock idea on the clutch set up sound like a good idea at first but safety wise it will kill you. Push in the clutch and hit the brakes on the top end , instant lock up and way you go. Put it on the shift handle not on the steering wheel,you need one hand on the shifter and one to remain on the steering wheel.
