steering column #334069
05/31/09 10:12 AM
05/31/09 10:12 AM
Way North Illinois
JandJ_Racing Offline OP
Way North Illinois
Does anyone know if there is an aftermerket steering column for a "B" body race car,with a rack and pinoin or do I make my own??
Re: steering column [Re: JandJ_Racing] #334070
05/31/09 12:40 PM
05/31/09 12:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
3/4" CM tubing with a universal joint... are you using
the stock column in the interior or is that different.
If you use more than 1 universal joint you will need
to hold the shaft with a over sized heim joint(.001
larger)flaming river has the U-joints and the coupler
for the rack and the over sized heim
Re: steering column [Re: JandJ_Racing] #334071
05/31/09 01:27 PM
05/31/09 01:27 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Flaming River...Ididit...there might be some more or you can make one like Mike suggested..
I made mine out of CM thats in my Duster..using a flaming river rack..
Re: steering column [Re: smokinwoody] #334072
05/31/09 06:25 PM
05/31/09 06:25 PM
Way North Illinois
Way North Illinois
CM is nice and light. I want to use my mig to put it together and I know thet is not the recomended process for moly although I did use it on my engine for and aft limiters. How about mild steel? I know heavy
Re: steering column [Re: JandJ_Racing] #334073
05/31/09 06:27 PM
05/31/09 06:27 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
tack it together with your mig, then get it tig welded somewhere...
....BAD A$$ STREET CAR.....
