440 decode required #333537
05/30/09 06:06 PM
05/30/09 06:06 PM
Canada
Lugnutz Offline OP
Lugnutz  Offline OP
Canada
Numbers on the pad are as follows
1st row.........6T 440 T E
2nd row.........3 1 8
Re: 440 decode required [Re: Lugnutz] #333538
05/30/09 06:08 PM
05/30/09 06:08 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Was this just posted the other day?
I thought the reply was 76 truck 440 cast crank trenton plant.
Re: 440 decode required [Re: RemCharger] #333539
05/30/09 07:57 PM
05/30/09 07:57 PM
Canada
Lugnutz Offline OP
Lugnutz  Offline OP
Canada
Geezzzh, I hope not!!! If I did it is an oversight on my part.
This is another engine that a guy wants to sell. Unfortunately don't know my codes for engines. The owner claims it came out of New Yorker
If it is another truck motor, then that's all I'm finding
Re: 440 decode required [Re: Lugnutz] #333540
05/31/09 12:09 AM
05/31/09 12:09 AM
Marshall, Texas
royt440 Offline
royt440  Offline
Marshall, Texas
6T = 1976
440 = 440
T = Trenton
E = not sure but it may be the body style (E-body)
318 may be month(March), 1(first day), 8 (eighth engine assembled that day
I certainly won't mind if someone else says that's all wrong.
There should be more codes on the oil pan rail.
Re: 440 decode required [Re: Lugnutz] #333541
05/31/09 12:11 AM
05/31/09 12:11 AM
Marshall, Texas
royt440 Offline
royt440  Offline
Marshall, Texas
Sorry, just noticed that E can mean cast crankshaft.
Re: 440 decode required [Re: Lugnutz] #333542
05/31/09 01:37 AM
05/31/09 01:37 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
6= 1976 model year
T= assembled at Trenton engine plant
440 = CID
T= for use in a truck
E= cast crank
318 assembled March 18th, 1976
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 440 decode required [Re: Lugnutz] #333543
05/31/09 09:36 AM
05/31/09 09:36 AM
AndyF Offline
AndyF  Offline
Worth taking a look at. The light truck motors are basically the same as passenger car motors so no big deal. The HD truck motors used different heads and a different cooling system.
