ram abs brake help needed #333463
05/30/09 03:30 PM
05/30/09 03:30 PM
Ohio
tak Offline OP
tak  Offline OP
Ohio
I have a 2002 1500 4x4, replaced the front hubs and now the abs and brake light are both on. I reused the old sensors with the new hubs. Any quesses to what's going on? How can I reset the light? or can't I.
Re: ram abs brake help needed [Re: tak] #333464
05/30/09 03:43 PM
05/30/09 03:43 PM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
Most of the time new hubs come with new sensors that need to be used because of mfg differences
Re: ram abs brake help needed [Re: tak] #333465
05/30/09 03:50 PM
05/30/09 03:50 PM
Caldwell, Idaho
67R/T4speeder Offline
Caldwell, Idaho
Double check your connection`s , if you turn truck off and restart it and light`s still come on then there is a problem . You might need to use a scanner to find which side is the problem . Anywhere near Marietta OH ?
Re: ram abs brake help needed [Re: mod381] #333466
05/30/09 04:25 PM
05/30/09 04:25 PM
Ohio
tak Offline OP
tak  Offline OP
Ohio
These were new MOPAR hubs for the 2008 recalls. I was told by the selling dealer that my sensors would work. When we were checking the hubs originally, the truck was in the air, in 4 wheel drive and put into gear. When the brakes were hit to stop the wheels,of course the fronts stopped first, the lights first came on then. They went off when the truck was being moved around after replacing the hubs but then came back on when it was drove on the road for the first time. Now staying on. Oh, the brakes were also bled earlier (that's how the bad hub was found).
Re: ram abs brake help needed [Re: tak] #333467
05/31/09 07:20 AM
05/31/09 07:20 AM
Ohio
tak Offline OP
tak  Offline OP
Ohio
btt
