Page 1 of 3 1 2 3
Getting rid or exhaust "drone" #333378
05/30/09 02:31 PM
05/30/09 02:31 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Hello,
On the 67 'cuda vert, I have a 300HP 360 crate motor, 340 exhaust manifolds and TTI exhaust going back with the TTI supplied Dynomax turbo mufflers.
Around 2200-3500 it has a real bad "drone" making the car a pain to drive (most of the driving is at these RPMs)
Can anyone suggest a good muffler which will get rid of this?
Re: Getting rid or exhaust "drone" [Re: 6T6Cuda] #333379
05/30/09 02:49 PM
05/30/09 02:49 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
If you don't have tail pipes that will cause a drone.
Re: Getting rid or exhaust "drone" [Re: Lefty] #333380
05/30/09 06:45 PM
05/30/09 06:45 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've heard two solutions from this problem. One is to put resonators on, I hear a pair of cheapie cherry bombs will do the trick.
Other thing I've heard (not sure if is true) is that staggering the mufflers distance from the headers/manifolds helps as well.
Re: Getting rid or exhaust "drone" [Re: Lefty] #333381
05/30/09 07:36 PM
05/30/09 07:36 PM
I had a 1/2 t pickup w turndowns right after the muffs(about halfway back). It was intolerable. I sold it before I ever dealt with it.
Re: Getting rid or exhaust "drone" [Re: RapidRobert] #333382
05/30/09 07:53 PM
05/30/09 07:53 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
[Quote]
[/Quote]
Full exhaust all the way out the back...
Re: Getting rid or exhaust "drone" [Re: 6T6Cuda] #333383
05/30/09 08:25 PM
05/30/09 08:25 PM
Orange County, CA
Mike H Offline
Mike H  Offline
Orange County, CA
I have the same problem with a 440-6 69 Roadrunner, factory cast iron manifolds, new TTI exhaust system for the rest. The system resonates inside the car so badly you almost cannot drive it. I was told to replace the mufflers with "hemi mufflers", whatever that means. When I restored my Challenger (383, stock), I promised myself to never do the TTI thing again. I used a stock system from Accurate Exhaust. Beautiful. Sounds like it did originally. When I get around to re-doing my Roadrunner, that TTI crap will go in the trash in favor of a stock muffler and resonator system.
Re: Getting rid or exhaust "drone" [Re: Mike H] #333384
05/30/09 09:41 PM
05/30/09 09:41 PM
qc
mxbeep Offline
mxbeep  Offline
qc
I used tti kits on both our b-body 440+6 cars and have no drone whatsoever, 1 car even as headers and mopar 528 cam.
I can barelly ear the exhaust noise from inside the car
Re: Getting rid or exhaust "drone" [Re: mxbeep] #333385
05/30/09 10:05 PM
05/30/09 10:05 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
my tti has H pipe, and walker dynomax. sounds fine.
Re: Getting rid or exhaust "drone" [Re: hemibeep] #333386
05/30/09 11:08 PM
05/30/09 11:08 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
I had the same problem on my 71 cuda 440. As soon as I took the manifolds off and put the headers on the drone was gone. It was much faster, and much nicer to drive.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Getting rid or exhaust "drone" [Re: Prodart440] #333387
05/31/09 07:19 PM
05/31/09 07:19 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
On my b-body I just replaced the factory HP manifolds and an H-pipe with cheapo headers and an x-pipe. Everything from the x-pipe back stayed the same.
My drone went away also!!!
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Getting rid or exhaust "drone" [Re: wingman] #333388
05/31/09 07:56 PM
05/31/09 07:56 PM
Beavercreek, Ohio
OA5599 Offline
OA5599  Offline
Beavercreek, Ohio
My 69 Cuda has TTI headers and 3" all of the way back to 3" factory style tips from TTI using Dynomax Ultraflos. I had a drone problem when first fitting the exhaust and taking it for a test drive. Once the tips went on and took the exhaust slightly past the bumper, the drone hasn't seemed to be a problem anymore.
Re: Getting rid or exhaust "drone" [Re: OA5599] #333389
06/01/09 12:35 AM
06/01/09 12:35 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Most of the problems are when using the factory exhaust manifolds my hand built system with factory manifolds, x pipe, dynomax Hemi mufflers 20" case, flowmasters tailpipes to tips, did the same thing as the original poster describes, i installed magnaflow resonators made of SS with SS packing, now very quiet !!
Re: Getting rid or exhaust "drone" [Re: ademon] #333390
06/01/09 06:34 AM
06/01/09 06:34 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
exhaust drone is actually a resonance, where the whole system is allowing the sound waves to basically "build up" and create the drone...kinda like blowing air over the top of an empty coke bottle.
and, every car combo is different! only way to figure it out yourself, is to experiment, change the length of the tail piples if you want, change the mufflers, add an H or X pipe, if you already have one, then try it without...
**Photobucket sucks**
Re: Getting rid or exhaust "drone" [Re: 70Cuda383] #333391
06/01/09 09:10 AM
06/01/09 09:10 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
on my 72 road runner, 572 hemi TTI big tube headers hooker areo chamber mufflers 3" X pipe exhaust, i had a exhaust drone. i changed the 3" tail pipes to 2 1/2" and now it sounds perfect. i put the car on a chassis dyno to measure hp loss. i lost 2hp with the change, but it was also 10 degrees warmer when i dynoed it the second time, so in my opinion there was no loss of hp with smaller tail pipes.
perception is 90% of reality
Re: Getting rid or exhaust "drone" [Re: 70Cuda383] #333392
06/01/09 11:09 AM
06/01/09 11:09 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I had that somewhat even with an H-pipe. Switched to an X-pipe. That fixed it. I like the tone now, too. Can hardly hear the exhaust from within the car at cruise.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Getting rid or exhaust "drone" [Re: DaytonaTurbo] #333393
06/02/09 11:03 AM
06/02/09 11:03 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
So does the exhaust drone come from the "sound" or from the "sound" resonating the pipes.
If from the latter then I need to modify the mount points to change the node points, if from the former changing the muffer or something should make a difference.
Anyone know what is the root cause cause of the "drone"??
Re: Getting rid or exhaust "drone" [Re: 6T6Cuda] #333394
06/02/09 11:13 AM
06/02/09 11:13 AM
I would add resonators or glasspacks at the tail end alongside your leafs. The sound is from the ex exiting not the pipes resonating. Not sure exactly what muffs I'd use there but there will be good suggestions for that
Re: Getting rid or exhaust "drone" [Re: 6T6Cuda] #333395
06/02/09 01:16 PM
06/02/09 01:16 PM
Detroit, Michigan, USA!
peelerboy Offline
peelerboy  Offline
Please see 70Cuda383's post:
Re: Getting rid or exhaust "drone" [Re: 6T6Cuda] #333396
06/02/09 01:17 PM
06/02/09 01:17 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
it happens when the exhaust system hits the natural frequency of the car. it's kind of a combination of both. another idea to try is to use muffler clamps to affix weight to the tailpipes. that adds mass damping and should change the resonant frequency of the exhaust.
2017 Grand Cherokee Overland
Re: Getting rid or exhaust "drone" [Re: patrick] #333397
06/06/09 10:59 AM
06/06/09 10:59 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
avoid tailpipe lengths behind the muffler in the range of 55 to 75 inches, otherwise you have created your own 'church organ pipe' that will resonate
alternatively,
break up these bad lengths with resonators... or use a muffler design with a 'Helmholtz Resonator' section
the noisy resonance depends on the
temperature & pressure of the exhaust gas too
(for geeks: actually the speed of sound for that gas condition)
so the rpm the noise is worst at will change slightly with the weather and with the throttle opening (you will hear this effect going up and down hills at the same rpm)
you can prove this to yourself by adding a two to three foot long section of exhaust pipe temporarily
notice that many imported cars have the muffler at the very end?
the science of this is the same as with
exhaust primary tube length on headers
and with intake manifold runner length
want to be very afraid of this effect?
see the movie
'The Perfect Storm'
where the gigantic "Rogue wave" at sea
is caused by the same resonance effect
Page 1 of 3 1 2 3
