Re: rear gear swap suggestion
[Re: RapidRobert]
#332796
05/29/09 09:53 PM
05/29/09 09:53 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
you could go up to a 3.55 but I wouldn't go further than that, unless you get an OD transmission
my 438 (same combo as your 451, but in a 383 block) had 3.21s with a 28" tire. in 4th gear (1:1) it would do around 65 with something like 2300, 2400 rpm.
but I have a 5th gear .64 OD...which I couldn't even think about using until I was going at least 75.
so I changed it to a 4.56 rear gear and can now do 65 at 2200 rpm in 5th, or 75 at 2600 rpm
**Photobucket sucks**
[Re: 70Cuda383]
#332797
05/29/09 09:54 PM
05/29/09 09:54 PM
70Cuda383
Marysville, O-H-I-O
oh, and with the 3.21s the 438 would roast the tires in 1st gear from a 20 mph roll, so it'll still be fun on the street!
