Re: 416 sm block stroker & rod ratio?
[Re: ragtop]
#332121
05/28/09 11:13 PM
05/28/09 11:13 PM
RapidRobert
I read up on it as I was contemplating going that route & yes(from what I gathered) that the 4" crank reduces the rod/stroke ratio almost to the point of the side loading being an issue but there was a long thread on stroking them & every one to a person said that after stroking their 340/360 that with the added street manners from the torque increase that they would never go back to using a stock stroke SB
[Re: cudasam]
#332125
05/31/09 12:58 AM
05/31/09 12:58 AM
RapidRobert
Goldmember. I have a 360/408 on paper & I have some badger .020 cast pistons w .017" clearance in a freshly bored/honed block. If I go with a 4" crank would the tight clearances here minimize the piston problems with this deal? 360/6.123" rods/5/64" rings, Daily driver low rpm
[Re: goldmember]
#332128
05/31/09 01:19 AM
05/31/09 01:19 AM
RapidRobert
My mistake I meant .0017" EDIT I have everything covered except I am wondering about any possible piston/wall problems from the side loading/rocking from the low rod/stroke ratio.
