The transmission will have the part number on the driver's side of the pan rail ...
part number will be -
PK2801541L abcd efgh----- (where "abcd" is a 10,000 day date code - around 2488 for your car) & (efgh is the production unit number)
The last 8 digits of the VIN# will be stamped about center top of the bellhousing
8G266xxx If you have to locate parts, why not locate the correct parts? IMHO any useable original numbered part, reunited with the car, enhances the overall quality/value/desirability of the car.
Josh, did you get your email?
