Anybody installed Scarebird disc brake brackets #331789
05/28/09 07:10 PM
05/28/09 07:10 PM
Ohio
V
viperakron Offline OP
V
Ohio
Ebay Item number: 370195150369 for 62-65 B Body
Says they bolt directly to drum spindles, uses a 73 rotor and 92-99 Ram calipers. Sounds like an easy way to go if they work. Any done it?
Re: Anybody installed Scarebird disc brake brackets [Re: viperakron] #331790
05/29/09 09:45 AM
05/29/09 09:45 AM
Texas
vynn3 Offline
vynn3  Offline
Texas
Do a search for "Scarebird". You should get plenty of results.
vm
Re: Anybody installed Scarebird disc brake brackets [Re: vynn3] #331791
05/29/09 11:33 AM
05/29/09 11:33 AM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Front and rear for me.......been on there for 2 years, they work good for me. One tip: buy a medium grip pad instead of stock, such as a performance Hawk pad.
Re: Anybody installed Scarebird disc brake brackets [Re: Viol8r] #331792
05/29/09 11:59 AM
05/29/09 11:59 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I have NO experience with these and therefore no opinion other than If I was selling brakes I would not use the word SCARE in the name.
Re: Anybody installed Scarebird disc brake brackets [Re: GomangoCuda] #331793
05/29/09 12:29 PM
05/29/09 12:29 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
how does that work, since all B body rotors are 1" thick, and the 94-01 ram rotors are 1 3/8" thick? do you get (or have to buy) pad spacers?
2017 Grand Cherokee Overland
Re: Anybody installed Scarebird disc brake brackets [Re: viperakron] #331794
05/29/09 02:09 PM
05/29/09 02:09 PM
Allentown,PA
68_300_conv Offline
68_300_conv  Offline
Allentown,PA
I have a set of their brackets on my 300 the brackets are fine , the spacers they sent me to make the rotors work were another story ... when the spacers were installed as provided there was no room to add a cotter pin the the end of the spindle, and the pads were not centered on the rotors. I sent a message to them asking for help and got no response ... I had a friend machine the spacers down .100 and then everything fit nicely.
SO they do work but they were far from a bolt on, and there is NO customer service after the sale ..
