Re: Excessive gas tank pressure
[Re: Magnumguy]
#331581
05/28/09 08:17 PM
05/28/09 08:17 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
I think the VENTED stuff on caps is just to let get in air when gas pump is suctioning, but not to release the pressure... I'm having the same deal, with some whistly sound when pressure is too high, throught the gas cap gasket
[Re: 2RTSE]
#331582
05/28/09 08:21 PM
05/28/09 08:21 PM
RapidRobert
I have had cars that gave out a big whoosh when you took the cap off to fill it & ran excellent. It had no problems other than the noise? I would suggest leave it or try another cap which you have to do now as the drilled hole will continue to dribble out when it's close to full & esp when you turn right.
[Re: NachoRT74]
#331583
05/28/09 09:35 PM
05/28/09 09:35 PM
Posts: 4,748 Florida
BDW
I think the VENTED stuff on caps is just to let get in air when gas pump is suctioning, but not to release the pressure... I'm having the same deal, with some whistly sound when pressure is too high, thought the gas cap gasket
I have the same problem and thought about drilling a hole in the cap, but as mentioned, the vented cap is designed to let air in, not out. I would definitely get another cap and check your vent line.
You should have a nipple on the filler tube that is connected to a line that exits through the trunk floor. This will let the pressure release.
[Re: 2RTSE]
#331587
05/28/09 10:17 PM
05/28/09 10:17 PM
RapidRobert
I know the 71's(late70's?) had nothing vented to the atmosphere due to the very strict gov't emission regs of that era & the tank was vented with a hard line up to the charcoal canister on the pass fender & fumes went from the canister to a (sealed)3 nipple breather cap on the pass valve cover then down into the crankcase then over & up to the PCV to be burned.
[Re: RapidRobert]
#331588
05/29/09 12:46 AM
05/29/09 12:46 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
The vented caps vent to outside air for pressure and vacum. When hot fuel cools it will pull a strong vacum so you have to vent under a vacum and with pressure when the fuel heats up and exspands. The newer cars that are sealed caps still release pressure and vacum at certain pressure and vacum settings as a safety feature in case the vent lines get blocked. I would replace the gas cap first with a good vented cap and see if that does it. Make sure it is a vented cap as I have seen guys think they got a vented cap and did not. Its not unusual to hear a little noise from a non-vented cap when it releases past its safety setting but vented caps dont usually make any noise because it is always vented and should not build pressure or vacum. Ron
[Re: 2RTSE]
#331589
05/29/09 06:11 PM
05/29/09 06:11 PM
BDW
My filler tube has no nipple for a vent line (never did). I seem to remember that 70's were different than other years. If the vented caps only let pressure (air) in then how is the pressure relieved? If it is through the tube as shown in your pic then why wouldn't that same tube let air in thus eliminating the need for a vented cap? Do some years/systems run with tanks at atmospheric and some under pressure? The body shop manual I have shows a vented cap for 70. I'll try to copy that section tomorrow and post it.
Here's my 70 cap, it's not vented.
