Ok, I want to install my rear window trim. The window is in, normally I would pull it and put the clips on and re-install the rear glass. HOWEVER after seeing the amount of filler in the sail panel and after seeing some of this guys work in other areas of the car I'd like to keep the window in. (don't really want any more suprises) I know I can "glue the trim in place but I was wondering if I could JB weld the clips in or use liquid nails to hold he clips in place. Otherwise it's trim adheasive city.
