finally going to try trans brake
#331304
05/28/09 08:27 AM
05/28/09 08:27 AM
Posts: 501 Port Mcneill,B.C.Canada
Islandcuda
Finally have time to go to the track saturday and try the trans brake. 67 cuda 440,727 auto, calvert bars with there springs. Car used to leave at 3000 rpm, now that the brake is in it stalls at 4600, what would you guys leave the line at, 4600 or try softer and work my way up? Thanks Tim
67 cuda new best 1.395 60 10.240 at 128.58mph
Re: finally going to try trans brake
[Re: Islandcuda]
#331306
05/28/09 09:07 AM
05/28/09 09:07 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Work your way up..... I hope you have a delay box, that way you wont expect it when it happens You may find(as I did) that coming up higher in the revs planted the tire much better
[Re: MR_P_BODY]
#331307
05/29/09 12:48 AM
05/29/09 12:48 AM
Islandcuda
lol no delay box just 2 step on the limiter, okay i,ll try maybe 4000 first time with my calvert bars and shocks set on the settings before the trans brake and see what happens. I guess a guy should do 2 hits mon one setting to a little more info/ Tim
[Re: toddd]
#331309
05/29/09 01:20 AM
05/29/09 01:20 AM
Posts: 1,087 Northeast, Arkansas
Dodgeman67
Northeast, Arkansas
Tim I am with Mr. P Body, start out with like a 3,000 chip and then just a few hundred at a time till you get to 4,000. Most of the time if you leave a little RPM to flash it will yeild better 60's times, but all cars are different. Yea you need a delay box, so when you let the button go, you just sit there and then bam you're gone.
[Re: Dodgem]
#331311
05/29/09 02:41 AM
05/29/09 02:41 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
Try less RPM and work up. be prepared it feels and sounds like you got hit by a truck from behind
This is exactly why i cant wait to put a brake in my car...
[Re: 493_DART]
#331312
05/29/09 04:00 AM
05/29/09 04:00 AM
Islandcuda
Great info guys, 200 rpm at a time, I,ll have to do time only,s after I screw up,lol. the lites yes that,s what,s it,s all about isn,t it, as I really don,t know what to expect, my button can have 3 100,s taken out of it or added. I used to leave right on the middle of the third yellow which was very hard to do with led lites.I,m thinking it should react quicker on the brake and leave at say the end of the third yello. but as some say every car reacts different, yikes gonna take me 12 runs to attain max stall , sounds like fun, Tim
[Re: Islandcuda]
#331313
05/31/09 12:50 PM
05/31/09 12:50 PM
Islandcuda
Well made to track and it didn,t go well, first time up go up on stall leave on the lite , car don,t go, huh, let off gas and it goes, what the heck, get to return road stop push down on button up on gas let go button all works well. Okay screwed up somewhere, try again same thing what the , now getting frustrated, try again, up on the stall, tree goes down, car still sitting what the again, dam, uh oh, forgetting to let go of the dam button,lmao.Try again forget the lites just try to leave with the break and all went well. So after being an idiot, I,m moving the button from behind the shifter to the wheel. It just doesn,t work for me there as just to dam busy,lol.
