air grabber flap assembly restoration #330789
05/27/09 08:35 PM
05/27/09 08:35 PM
NY
70440+6bbl Offline OP
NY
I just disassembled my '71 GTXs air grabber flap assembly and need to figure out what plating was used on the misc parts? Basically: the long rod, flapper hinges, and the end bracket that the assist spring attaches to.
Are the end caps and flapper door the same color orange as the air cleaner lid?
Re: air grabber flap assembly restoration [Re: 70440+6bbl] #330790
05/28/09 10:18 AM
05/28/09 10:18 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
The long rod and bracket for pod should be black zinc. Roll pins are clear zinc. And the end caps and flapper are AC orange as you already suspected.
Re: air grabber flap assembly restoration [Re: hemi70se] #330791
05/28/09 06:37 PM
05/28/09 06:37 PM
NY
NY
Thanks Dirk,
Were the flapper hinges and the assist spring bracket the same?
Re: air grabber flap assembly restoration [Re: 70440+6bbl] #330792
05/29/09 12:11 AM
05/29/09 12:11 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Yes the flapper hinges are the same black zinc. I didn't mention the flapper assist spring because I can't recall if I did that black phosp. or clear zinc. Be sure to take pics of it all before you take it apart. You'll be glad you did , since the hinges can be mounted backwards.
Re: air grabber flap assembly restoration [Re: hemi70se] #330793
05/29/09 09:42 AM
05/29/09 09:42 AM
NY
NY
Thanks again:) I made sure to draw a diagram and snap a few pics
