Re: Small Block 587 Heads Question
[Re: smokkem]
#330318
05/27/09 02:27 PM
05/27/09 02:27 PM
Posts: 15,487 Florida
scratchnfotraction
just get a set of the comp 901-16 springs drop on with stock seals with out R&R the heads single with a damper what spring rate are your springs?
[Re: smokkem]
#330321
05/27/09 03:25 PM
05/27/09 03:25 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
That is only .020 less than 1/8 inch. That is alot of cut. I would remeasure. Standard recommended installed height is 1.68/1.70 so .100 would put you right in at the 1.70 installed height. IMO you have either mismeasured, or the valve are sitting too high on the seats, or you have shimmed the spring seats but even a standard valve will sit at close to the 1.68 mark. you shouldn't need any cutting to get the 1.70 measurment. Depending on the cam lift remember to check the retainer clearance between the guide/seal and the retainer at full valve lift. PS: I have standard length valves installed at 1.8 but used a dished retainer to achieve the extra. There really isn't much extra meat in the spring seats.
[Re: MoparforLife]
#330322
05/27/09 03:42 PM
05/27/09 03:42 PM
Posts: 7,506 Az
Crizila
Az
What about running off-set keepers?
Fastest 300
[Re: smokkem]
#330325
05/27/09 06:29 PM
05/27/09 06:29 PM
RapidRobert
it would come down to how much material there is(in the seats) to work with but I think I'd try to get there with parts(you might check hughes's retainers) plus less machine shop labor bill EDIT if you do hit water or too close to it I have a pair of 587's you can have for free if you come up here to Nebraska & pick them up or $50 for my time if I wrap them & take them to the bus depot & send them collect.
[Re: smokkem]
#330327
05/27/09 09:42 PM
05/27/09 09:42 PM
RapidRobert
I have a deal for you that you cant refuse. you have mail
[Re: smokkem]
#330328
05/27/09 10:26 PM
05/27/09 10:26 PM
MoparforLife
Upper Midwest
Thanks for your help and the 587 offer. I think we are going with parts and a little off the spring seat. I was hoping somebody out there had precise experience with shaving a little off the spring seat. Let me ponder the 587 for 50, but don't wait on me if somebody else needs them.
The experience I have had from Hughes and a couple of other machinsits is DON'T. That there is very little meat to work with and that spring support will be next to nil. The most I have ever taken or had taken is enough to true slightly.
[Re: MoparforLife]
#330329
05/28/09 09:18 AM
05/28/09 09:18 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
what beehive springs are you using specifically? could you switch to PN 26986? at 1.6" IH you don't have a lot of room before coil bind with any spring.... another spring that MAY be a perfect spring for you are stock GM 3100-3400-3500 60 degree pushrod V6 springs. they're a beehive, have the same top dia as an LS1 spring and I think the comps, are ~360 lb/in rate, are ~1.94" free length, 1.065" coil bind height, and have a seat pressure of ~110 lb@1.6" IH here's the data sheet from rockauto, and the cheap magnum spring thread from the "best of"
