Tranny Lines?? #330271
05/27/09 12:41 PM
05/27/09 12:41 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
For those of you with aftermarket Trans coolers, what do you use for trans lines?
My B&M cooler has 1/2"npt fittings. I'm wondering what size of line I should run.
Re: Tranny Lines?? [Re: mopowers] #330272
05/27/09 12:48 PM
05/27/09 12:48 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I bought braided lines and fittings from Summit, nice clean install and IMHO much easier/better than hard lines. If you want you can get a trans line kit from CRT and be done with it, it comes with lines and fittings.
Re: Tranny Lines?? [Re: GTXKen] #330273
05/27/09 01:45 PM
05/27/09 01:45 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I plumbed mine with 3/8's hard line....
1MYTGTX
Re: Tranny Lines?? [Re: GTXKen] #330274
05/27/09 03:00 PM
05/27/09 03:00 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
What size lines did you use?
Re: Tranny Lines?? [Re: mopowers] #330275
05/27/09 03:22 PM
05/27/09 03:22 PM
GTXKen Offline
super gas
GTXKen  Offline
super gas
-6 an
Re: Tranny Lines?? [Re: GTXKen] #330276
05/29/09 12:48 AM
05/29/09 12:48 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
count another with -6 braided line. I ran mine over to the frame rail and up. feel much better about it now than with hard lines.
Re: Tranny Lines?? [Re: StealthWedge67] #330277
05/29/09 10:31 AM
05/29/09 10:31 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Are rubber trans lines a no-no?
Re: Tranny Lines?? [Re: mopowers] #330278
05/29/09 10:53 AM
05/29/09 10:53 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
I know that the answer is .. NO !
Re: Tranny Lines?? [Re: dOrk !] #330279
05/29/09 11:03 AM
05/29/09 11:03 AM
United States
STLDuster Offline
STLDuster  Offline
United States
Why is that?
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Tranny Lines?? [Re: STLDuster] #330280
05/29/09 11:40 AM
05/29/09 11:40 AM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Why ? .. because people do it all the time!
He11 ...I put on cooler on my 62 in 1970 .... and there are rubber lines on that have never been changed. They look and feel fine.
Re: Tranny Lines?? [Re: mopowers] #330281
05/29/09 12:45 PM
05/29/09 12:45 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
If you want bullet proof use the teflon lined -6 lines. More expensive, but you will not worry down the road about rubber deterioration.
Re: Tranny Lines?? [Re: Lefty] #330282
05/29/09 01:26 PM
05/29/09 01:26 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
If you use the correct rubber lines you are OK.. I went to a hydraulic hose shop and the sold me hose that won't fall apart in oils and is rated to handle 300 psi..this stuff is used on hydraulic equipment n stuff .. Been on for 3 years and no problems...
Re: Tranny Lines?? [Re: dynamite] #330283
05/29/09 01:33 PM
05/29/09 01:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
it also wants to be rated for over 400*F
Re: Tranny Lines?? [Re: JohnRR] #330284
05/29/09 07:23 PM
05/29/09 07:23 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Is it okay to mount the cooler with the lines pointed down?
