Re: Tranny Lines??
[Re: GTXKen]
#330273
05/27/09 01:45 PM
05/27/09 01:45 PM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
I plumbed mine with 3/8's hard line....
1MYTGTX
Re: Tranny Lines??
[Re: GTXKen]
#330274
05/27/09 03:00 PM
05/27/09 03:00 PM
Posts: 3,010 Sac, CA
mopowers
Sac, CA
I bought braided lines and fittings from Summit, nice clean install and IMHO much easier/better than hard lines. If you want you can get a trans line kit from CRT and be done with it, it comes with lines and fittings.
What size lines did you use?
Re: Tranny Lines??
[Re: mopowers]
#330275
05/27/09 03:22 PM
05/27/09 03:22 PM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
-6 an
Re: Tranny Lines??
[Re: GTXKen]
#330276
05/29/09 12:48 AM
05/29/09 12:48 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
count another with -6 braided line. I ran mine over to the frame rail and up. feel much better about it now than with hard lines.
Re: Tranny Lines??
[Re: mopowers]
#330278
05/29/09 10:53 AM
05/29/09 10:53 AM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
Are rubber trans lines a no-no?
I know that the answer is .. NO !
Re: Tranny Lines??
[Re: mopowers]
#330281
05/29/09 12:45 PM
05/29/09 12:45 PM
Posts: 6,516 Santa Cruz, California
Lefty
If you want bullet proof use the teflon lined -6 lines. More expensive, but you will not worry down the road about rubber deterioration.
Re: Tranny Lines??
[Re: dynamite]
#330283
05/29/09 01:33 PM
05/29/09 01:33 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
If you use the correct rubber lines you are OK.. I went to a hydraulic hose shop and the sold me hose that won't fall apart in oils and is rated to handle 300 psi..this stuff is used on hydraulic equipment n stuff .. Been on for 3 years and no problems...
it also wants to be rated for over 400*F
