turn signal issue #330175
05/27/09 10:30 AM
05/27/09 10:30 AM
wisconsin
dodger1 Offline OP
dodger1  Offline OP
wisconsin
Recently my turn signals either dont flash or they flash real fast and random, if I push the lever down they stay lite with no flashing, the emergency lights work fine, just hoping someone knows what it might be. thanks
Re: turn signal issue [Re: dodger1] #330176
05/27/09 10:37 AM
05/27/09 10:37 AM
TS flasher can
Re: turn signal issue [Re: RapidRobert] #330177
05/27/09 10:51 AM
05/27/09 10:51 AM
wisconsin
dodger1 Offline OP
dodger1  Offline OP
wisconsin
I tried a new flasher no change. thanks
Re: turn signal issue [Re: RapidRobert] #330178
05/27/09 10:59 AM
05/27/09 10:59 AM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
I agree - start with the flasher itself.
It doesn't hurt to have a basic understanding of how the flasher in a domestic classic car works - it's simply a low capacity circuit breaker. The load of lighting the turn signal bulbs heats it up, causing it to open the circuit. Once the circuit is open (without load), things cool down, and the breaker closes again. Repeat.
Your symptoms sound like a mix. Things other than a haywire flasher sort of go like this:
a. Flashes very slow or not at all: Insufficient load on the circuit. Often simply a bulb burned out.
b. Flashes faster than normal: Higher load on the circuit than expected. Dirty, higher resitance socket. Perhaps a vandal connected a trailer (with its additional lights) without your knowledge.
Down to just a blue car now.
Re: turn signal issue [Re: 68HemiB] #330179
05/27/09 11:08 AM
05/27/09 11:08 AM
yes that is a different mix of symptoms. Is the can grounded good.
Re: turn signal issue [Re: RapidRobert] #330180
05/27/09 11:18 AM
05/27/09 11:18 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you change the right flsaher? There are two. One for the turn signals and one for the emergency lights.
Re: turn signal issue [Re: stumpy] #330181
05/27/09 11:21 AM
05/27/09 11:21 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
a speedy flash sometimes can be caused by a burned bulb somplace..
Coming soon!!!!
Re: turn signal issue [Re: RapidRobert] #330182
05/27/09 11:43 AM
05/27/09 11:43 AM
Shoreline, Washington
72roadrunnergtx Offline
"Is the can grounded good?"
A ground is not required for the any turn signal flashers on these cars.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: turn signal issue [Re: 72roadrunnergtx] #330183
05/27/09 11:50 AM
05/27/09 11:50 AM
I've had a few that did not work right with the can dangling & I put it back in it's holder & it went back to normal.
Re: turn signal issue [Re: RapidRobert] #330184
05/27/09 01:38 PM
05/27/09 01:38 PM
wisconsin
dodger1 Offline OP
dodger1  Offline OP
wisconsin
thanks guys, I will look for he other flasher the can is the spacer between the wheel and the column right, I have a rimblow, I need to check the other flasher becuase I dont get anything when I flip the turn signal now it just stopped lighting up when I put the switch up or down before it would stsy lite. thanks
Re: turn signal issue [Re: dodger1] #330185
05/27/09 01:40 PM
05/27/09 01:40 PM
wisconsin
dodger1 Offline OP
dodger1  Offline OP
wisconsin
Anybody know were the second flasher on a demon would be I found one with pink wires but I ddnt see another one is it behind the kick panel thanks
Re: turn signal issue [Re: dodger1] #330186
05/27/09 01:51 PM
05/27/09 01:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It won't be behind the kick pad. It might be either next to the ash tray or over near the glove box under the dash IIRC.
Re: turn signal issue [Re: stumpy] #330187
05/27/09 01:57 PM
05/27/09 01:57 PM
wisconsin
dodger1 Offline OP
dodger1  Offline OP
wisconsin
Three cheers for stumpy, Thank you that was it.
Re: turn signal issue [Re: dodger1] #330188
05/27/09 02:06 PM
05/27/09 02:06 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I like a simple cheap fixes.
