Pick my rear end gear ratio. #330013
05/26/09 11:33 PM
05/26/09 11:33 PM
MN
dustyswinger Offline OP
MN
I am thinking of changing a couple of things and was wondering what you guys think. I have a 73 duster that is just a bracket car, it has a 416 stroker with about 500 HP and TQ. It is a pretty good combination that runs 10.50's and 123(it is down, previous best is 126.5 and and the motor is apart for fresening) It has 9.8 compression and last year I was running 4.56 gears that broke towards the end of the year and didn't bother to change them and I am thinking on changing pistons to 11.5 compression being it is apart. It has a cast crank that I don't want to spin past 7000 rpm, so I was thinking the pistons should pick up some ET and mph so instead of replacing the 4.56's I would try some 4.30's. I figure it might slow my 60's but they are low 1.40's and that dosent bother me. Just wondering what you would suggest and if any of you have been here before. Thanks Craig
Re: Pick my rear end gear ratio. [Re: dustyswinger] #330014
05/26/09 11:41 PM
05/26/09 11:41 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
You will gain some torq. with the higher compression,so IMO you should be faster overall with less gear,,,,4.30`s
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Pick my rear end gear ratio. [Re: dustyswinger] #330015
05/26/09 11:49 PM
05/26/09 11:49 PM
California, USA
P
Phil Saran Offline
Phil Saran  Offline
P
California, USA
Craig,
You may want to go back to 4:56 or even 4:88.
I have a buddy with a similar combo to yours,
but with 4:30 gears.
His motor is a 408 stroker, Edelbrock aluminum
heads that have been ported, a much bigger carb
than you run, compression similar to the 11.5
you are looking at, similar stall convertor, 904 trans with low gears.
Car is somewhat heavy at around 3400 lbs (67 Cuda FB)but
it's best runs have been 10.98 @ 121 at Vegas
and then 10.92 @ 123 at Fontana CA
Phil Saran Parker, Colorado
Re: Pick my rear end gear ratio. [Re: Phil Saran] #330016
05/27/09 06:58 AM
05/27/09 06:58 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
IMO the 4.30 gear is one of the best overall 1/8th mile, 1/4 mile gears around.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Pick my rear end gear ratio. [Re: dustyswinger] #330017
05/27/09 07:10 AM
05/27/09 07:10 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
How tall are your tires?
You probably stand more of a chance breaking the
crank @ 6700 with 11.5:1 than 9.8:1 and 7000.
Re: Pick my rear end gear ratio. [Re: S/ST 3040] #330018
05/27/09 05:54 PM
05/27/09 05:54 PM
MN
MN
The tires are 30X9 radial slicks.
Re: Pick my rear end gear ratio. [Re: dustyswinger] #330019
05/31/09 12:27 PM
05/31/09 12:27 PM
MN
MN
Any other's opinion?
Re: Pick my rear end gear ratio. [Re: dustyswinger] #330020
05/31/09 12:57 PM
05/31/09 12:57 PM
S/ST 3040 Offline
S/ST 3040  Offline
Let's see all of your cam specs, converter information and race weight.
Re: Pick my rear end gear ratio. [Re: S/ST 3040] #330021
05/31/09 03:32 PM
05/31/09 03:32 PM
MN
MN
Cam is a .600 lift with 268 duration mechanical, car weighs 3165 with me in it and the convertor is a dynamic 9 1/2 with 4200 stall. 1 7/8 headers, 950 hp holley and MSD ign.
Re: Pick my rear end gear ratio. [Re: dustyswinger] #330022
05/31/09 04:13 PM
05/31/09 04:13 PM
S/ST 3040 Offline
S/ST 3040  Offline
4.30 with a better converter and/or compression.
4.56 seems to be working with what you have.
Factory heads.
Re: Pick my rear end gear ratio. [Re: S/ST 3040] #330023
05/31/09 04:39 PM
05/31/09 04:39 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
4.10's on a 28" tire and a stroker seems to be on the fastest smallblock stroker a-bodies around here..
so with 30" id say 4.30 should work well.and keep that converter effecient..fwiw..
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Pick my rear end gear ratio. [Re: S/ST 3040] #330024
05/31/09 10:15 PM
05/31/09 10:15 PM
MN
MN
S/ST Yes factory smogger heads. A couple of friends have stepped up their combo and I don't want to be left in the dust. I think the 4.30's and 11.5 will work too.
Thanks Guys for all your input.
Re: Pick my rear end gear ratio. [Re: dustyswinger] #330025
08/24/09 07:28 PM
08/24/09 07:28 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
wow, that cam and only 9.8:1 compression... what cam is that? I might want to try it
Re: Pick my rear end gear ratio. [Re: dustyswinger] #330026
08/24/09 08:31 PM
08/24/09 08:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What were you turning with the 4.56 before
Re: Pick my rear end gear ratio. [Re: MR_P_BODY] #330027
08/24/09 08:54 PM
08/24/09 08:54 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
4.56 will help get the car out of the hole...4.88's might mean to much rpm through the 1/4...If you were a 8th mile racer like me, i would suggest 8th mile.
Re: Pick my rear end gear ratio. [Re: aarcuda] #330028
08/25/09 12:47 AM
08/25/09 12:47 AM
MN
MN
AAR cuda it was a cam motion cam they speced out for my application. If you want specs let me know. fastboy73@aol.com
PBody. I believe it went through at about 7000 before
