Tranny leaking #329761
05/26/09 08:21 PM
05/26/09 08:21 PM
Anonymous OP
Anonymous OP
I'm sure everyone is sick of hearing about my problems, but anyways my transmission is leaking on my automatic Dakota. It was recently rebuilt. Its coming out of the shaft that the shifter and kick down go onto. The guy who built it said its coming out of an overflow. The tranny is not overfull. The only thing I can think of is, I installed an aftermarket cooler, and maybe its running down the lines and overfilling it when its off, but something still seems wrong. I have fluid all over my driveway and i'm sick of buying fluid at $6 a quart. Anyone else ever have this problem?
Re: Tranny leaking #329762
05/26/09 08:24 PM
05/26/09 08:24 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Clen-it-off with some brake-clean ... let it dry ... and sprinkle some baby powder on it.
Any leak will show up directly.
Re: Tranny leaking #329763
05/26/09 08:25 PM
05/26/09 08:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Don't guess at the source of the leak, get a can of spray brake cleaner, clean off all of the fluid and then use a mirror and flashlight to pinpoint the source of the leak.
Re: Tranny leaking [Re: John_Kunkel] #329764
05/26/09 08:28 PM
05/26/09 08:28 PM
Anonymous OP
Anonymous OP
Not guessing, I know thats where its coming from.
Re: Tranny leaking #329765
05/26/09 08:35 PM
05/26/09 08:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you're absolutely sure it's coming from the shift shaft and it was recently rebuilt the rebuilder should take care of it. The seal should hold any overfull condition.
Re: Tranny leaking [Re: John_Kunkel] #329766
05/27/09 08:12 AM
05/27/09 08:12 AM
scratchnfotraction Offline
it could be from a cracked brass fitting at the line going in the tranny leaking down to the shift selecter seal...
rebuilder should have changed it,might have,could have been damaged putting the vb back in
and there are 2 seals at the shaft,selecter shaft seal and the throttle presssure valve seal,most times the tpv seal is over looked
I would be at the tranny shop
and double check the lines,are they tight,have rubber and clamps any where in the lines
the vent would blow it out and be in the bell housing and slung around by the torque verter,looks like a front seal leak
have a dust cover on it?
Re: Tranny leaking [Re: scratchnfotraction] #329767
05/27/09 05:42 PM
05/27/09 05:42 PM
Anonymous OP
Anonymous OP
Definatly coming from the shaft. The guy who built it did it out of his garage. Here's the latest. He won't return any of my calls so I guess i'm screwed. So much for my 1 year warrenty. Its going to a mechanic at the end of the week, because I looked at it, and have no clue how to replace it, and I don't want to mess anything up.
Re: Tranny leaking #329768
05/27/09 08:09 PM
05/27/09 08:09 PM
Andrewh Offline
Andrewh  Offline
The outside one is pretty easy to do. You don't even have to pull the pan.
They make a tool that screws into it to pull it out, and something like a deep socket to put the new one in.
Re: Tranny leaking #329769
05/27/09 08:12 PM
05/27/09 08:12 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Which shaft is it ? ... and to do-it-REALLY-right ... the valve body should come out.
