8.75 SG what lube #329666
05/26/09 06:46 PM
05/26/09 06:46 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
What should I use for rear end grease in a 8.75 SG
Not sure if it's a cone or clutch type the carrier is a 741.
Re: 8.75 SG what lube [Re: flatiron] #329667
05/26/09 09:14 PM
05/26/09 09:14 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Unless the unit was changed it's a clutch. you will need run a friction additve, BG has always worked good for me. If you buy something like Red Line gear lube or Royal Purple gear lube they already have the additive.
Re: 8.75 SG what lube [Re: flatiron] #329668
05/26/09 09:42 PM
05/26/09 09:42 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
If you haven't put the gears in yet and could get a picture posted to us, we could tell you whether it's a clone or clutch. I've yet to try the Royal Purple stuff, but I hear it's good. As stated, it will have all the additive that you'd need
Re: 8.75 SG what lube [Re: 68Bullit] #329669
05/26/09 09:58 PM
05/26/09 09:58 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Got it in two of my cars with clutch type sure grips and I'm happy with it.
