ramcharger cable #329621
05/26/09 06:09 PM
05/26/09 06:09 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
My N96 cable comes out of the firewall where my new electonic voltage regulator needs bolted to. I'm switching back to points. I'm thinking the cable should come out of the firewall elsewhere maybe just below the balaster. This is a 383 ramchager if that makes a difference. Looking for the proper location. Thanks
Re: ramcharger cable [Re: 70 buzz] #329622
05/26/09 06:55 PM
05/26/09 06:55 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Does this help;
Cheers,
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: ramcharger cable [Re: DPelletier] #329623
05/26/09 07:01 PM
05/26/09 07:01 PM
DPelletier Offline
DPelletier  Offline
maybe not;
mind you; this one doesn't have the right grommet either.
Re: ramcharger cable [Re: DPelletier] #329624
05/26/09 07:04 PM
05/26/09 07:04 PM
DPelletier Offline
DPelletier  Offline
Another;
...now I'm gonna hafta go look at mine when I get home to see which holes I've used so far....
Re: ramcharger cable [Re: DPelletier] #329625
05/26/09 07:06 PM
05/26/09 07:06 PM
DPelletier Offline
DPelletier  Offline
OK, I'm officially getting nowhere!!!!!
Re: ramcharger cable [Re: DPelletier] #329626
05/26/09 07:08 PM
05/26/09 07:08 PM
DPelletier Offline
DPelletier  Offline
I don't think either of the first two are right. I'll see if I have anything better at home.
Re: ramcharger cable [Re: DPelletier] #329627
05/26/09 08:05 PM
05/26/09 08:05 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
The first picture posted looks like the only way I can get my voltage regulator on unless the cable supposed to run below the voltage regulator but the way it stands now the cable hole is right in the way
Re: ramcharger cable [Re: 70 buzz] #329628
05/26/09 08:35 PM
05/26/09 08:35 PM
Grand Rapids MI
N
N9671X2 Offline
N9671X2  Offline
N
Grand Rapids MI
The original grommet was painted on my car when I got it, but you can see where it is, right below the voltage regulator.
Re: ramcharger cable [Re: N9671X2] #329629
05/26/09 09:49 PM
05/26/09 09:49 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
This suppose to be the right regulator but there is no way to mount it without interference with the cable hole
Re: ramcharger cable [Re: 70 buzz] #329630
05/27/09 07:51 AM
05/27/09 07:51 AM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
maybe Bill Allphin will chime in and give us an answer
Re: ramcharger cable [Re: 70 buzz] #329631
05/27/09 08:10 AM
05/27/09 08:10 AM
Detroit
Kidsixpack Offline
Kidsixpack  Offline
Detroit
I don't have the car available to look at, but If memory serves my cable enters the firewall directly below the voltage regulater on the left side. There is only one left side of a car.
KID
Re: ramcharger cable [Re: N9671X2] #329632
05/27/09 11:46 AM
05/27/09 11:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
do you have the BRACKET that bolts to the firewall that the regulator bolts to ? 1970 relutors do not bolt directly to the firewall on a B body they use a bracket that bolted to the two holes that a 69 down style regulator would bolt to so your perfumed groment is probaly in the correct place IF your car is an original N96 car .
Re: ramcharger cable [Re: DPelletier] #329633
05/27/09 11:50 AM
05/27/09 11:50 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the second one is definitely not correct , that hole is for the plug that holds the firewall pad inplace , first one , at least the person used an existing firewall dimple ...
Re: ramcharger cable [Re: JohnRR] #329634
05/27/09 12:29 PM
05/27/09 12:29 PM
DPelletier Offline
DPelletier  Offline
I took a look at mine again last night;
- John's right, the second one is wrong for sure; it is the hole for the insulation fastener as noted.
- the first one is wrong too; most don't even have a hole in this dimple (although mine does, but who knows if it's supposed to)
- I think John is correct: the box mounts to a bracket that mounts to the firewall, it doesn't mount directly to it. My current thinking is that the purple car is right and the bracket gives you the necessary clearance.
Re: ramcharger cable [Re: DPelletier] #329635
05/27/09 02:03 PM
05/27/09 02:03 PM
Grand Rapids MI
N
N9671X2 Offline
N9671X2  Offline
N
Grand Rapids MI
Here is the above purple car, original n96 car.
Re: ramcharger cable [Re: N9671X2] #329636
05/27/09 02:21 PM
05/27/09 02:21 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Now that makes sense thanks Paul
Re: ramcharger cable [Re: 70 buzz] #329637
05/27/09 02:51 PM
05/27/09 02:51 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Different plants and possibly different date of production (relocated due to interference with the voltage regulator??) changed the location of "Ramcharger/Air Grabber" grommet/cable locations on '70 b-bodies.
My N96 '70 GTX ..... built in LA "E" ..... February of 1970
Re: ramcharger cable [Re: 6bblgt] #329638
05/27/09 02:55 PM
05/27/09 02:55 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Looks like its in the same location on my 69 R/T.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: ramcharger cable [Re: AZ_A12_BEE] #329639
05/27/09 03:10 PM
05/27/09 03:10 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Dave please clean your engine compartment!!!
Re: ramcharger cable [Re: RJS] #329640
05/27/09 03:15 PM
05/27/09 03:15 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Better dust than rust I always say.
