Re: ramcharger cable
[Re: DPelletier]
#329624
05/26/09 07:04 PM
05/26/09 07:04 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Another; ...now I'm gonna hafta go look at mine when I get home to see which holes I've used so far.... Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#329626
05/26/09 07:08 PM
05/26/09 07:08 PM
DPelletier
I don't think either of the first two are right. I'll see if I have anything better at home.
1974 'Cuda
[Re: DPelletier]
#329633
05/27/09 11:50 AM
05/27/09 11:50 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
the second one is definitely not correct , that hole is for the plug that holds the firewall pad inplace , first one , at least the person used an existing firewall dimple ...
[Re: JohnRR]
#329634
05/27/09 12:29 PM
05/27/09 12:29 PM
DPelletier
I took a look at mine again last night; - John's right, the second one is wrong for sure; it is the hole for the insulation fastener as noted. - the first one is wrong too; most don't even have a hole in this dimple (although mine does, but who knows if it's supposed to) - I think John is correct: the box mounts to a bracket that mounts to the firewall, it doesn't mount directly to it. My current thinking is that the purple car is right and the bracket gives you the necessary clearance. Dave
1974 'Cuda
[Re: N9671X2]
#329636
05/27/09 02:21 PM
05/27/09 02:21 PM
Posts: 1,893 michigan
70 buzz
michigan
Here is the above purple car, original n96 car.
Now that makes sense thanks Paul
[Re: AZ_A12_BEE]
#329639
05/27/09 03:10 PM
05/27/09 03:10 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Different plants and possibly different date of production (relocated due to interference with the voltage regulator??) changed the location of "Ramcharger/Air Grabber" grommet/cable locations on '70 b-bodies.
Looks like its in the same location on my 69 R/T.
Dave please clean your engine compartment!!!
