Re: VIN on rear trunk panel.
[Re: SD800]
#329526
05/26/09 04:49 PM
05/26/09 04:49 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
68 Dart and 69 coronet.
They should both have numbers , about half to 3/4 way back on the left trunk lip , you have the rubber seal pulled up ?
[Re: JohnRR]
#329527
05/26/09 05:00 PM
05/26/09 05:00 PM
Posts: 388 Michigan
SD800
I have the rubber seal pulled up on both, it's on the dutcman panel correct?
You'll have plenty of time to sleep when your dead, let's go
[Re: SD800]
#329531
05/27/09 11:29 AM
05/27/09 11:29 AM
JohnRR
U.S.S.A.
On your 68 that will be the VON # NOT your VIN, should be same VON # on data Plate. Your Data plate will not have your VIN on a 68. Vehicle Order Number will be on Rad. Support.left trunk rail and date plate, last #s on bottom line
Oh, so the number on the radiator support will not match my VIN number, I thought they should match, thats why I could not find the letters in my book. Unfortunatley my car was a race car and my fender tag is long gone
The only way to tie the number on the body to the VIN on pre 69 cars is with the broadcast sheet or the IBM card .
i'm home today, I think I caught swine flu fromn the GF's newphew , if I get ambitious I'll go clean off the trunk lid of the dart and measure down how far it is , but no it's not on the dutchman as someone pointed out .
[Re: JohnRR]
#329532
05/27/09 01:13 PM
05/27/09 01:13 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
i'm home today, I think I caught swine flu fromn the GF's newphew...
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 69CoronetRT]
#329533
05/27/09 03:32 PM
05/27/09 03:32 PM
Posts: 6,301 colorado
a12superbee
colorado
Look on the underside of the lip, you can sometimes see the dimples and that will tell you where to look on the topside.
I can't afford this.
mark
