Can someone recommend a head gasket. I blew mine.
#329229
05/26/09 03:03 PM
05/26/09 03:03 PM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
I had fel pro blues in my 416 sb with 12:1 static compression. I blew #4 into the lifter valley on Friday at Island Dragway. Do i go with the fel pro again and right it off to too much timing,,,, which I had just advanced a few degrees,,, or is there something else I should use? It has eddy heads. It was a hot day, 95 degrees, and I did make alot of passes, and I did throw some extra timing at it... I know I know,, a recipe for disaster... and the recipe worked. HA. How about head studs,, would that help any?
Chris from New Jersey
Re: Can someone recommend a head gasket. I blew mine.
[Re: fig426]
#329230
05/26/09 03:07 PM
05/26/09 03:07 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
are you running the regular felpros or the performance ones I am running the felpro performance part # 1008 on a 416 with 12.8-1 timimng locked at 37 degrees and have had 0 problems so far.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#329231
05/26/09 03:18 PM
05/26/09 03:18 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i really like the edelbrock head gaskets. been on my engine for years
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: fig426]
#329233
05/26/09 04:29 PM
05/26/09 04:29 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
The number on the gasket itself is 8553PT with a R12 under it.
8553PT is the standard Fel-Pro head gasket, which works fine with iron head/iron block combinations.
1008 is designed for aluminum heads and more expensive.
No gasket will seal if either the the block or heads are not machined flat. Studs will help.
BTW,
8553_________12.14 cc volume-.054" thick 1008_________8.77 cc volume-.039" thick
[Re: emarine01]
#329235
05/26/09 05:19 PM
05/26/09 05:19 PM
fig426
East Coast, NJ
And.......... I just pulled the other head and #3 is almost blown through....... So I'll be ordering studs and I'll have to choose a gasket.
[Re: qwkmopardan]
#329242
05/27/09 12:27 PM
05/27/09 12:27 PM
dusturbd340W5
Kissimmee Fl.
I guess what ever works I am running 1008's with 12.8-1 with studs torqued to 100 lbs no retorque and no problems so far and I have been running the snot out of it.
[Re: dusturbd340W5]
#329243
05/27/09 12:42 PM
05/27/09 12:42 PM
Posts: 2,128 sweden
sshemi
sweden
Me to.
