Can someone recommend a head gasket. I blew mine. #329229
05/26/09 03:03 PM
05/26/09 03:03 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
I had fel pro blues in my 416 sb with 12:1 static compression. I blew #4 into the lifter valley on Friday at Island Dragway. Do i go with the fel pro again and right it off to too much timing,,,, which I had just advanced a few degrees,,, or is there something else I should use? It has eddy heads. It was a hot day, 95 degrees, and I did make alot of passes, and I did throw some extra timing at it... I know I know,, a recipe for disaster... and the recipe worked. HA. How about head studs,, would that help any?
Chris from New Jersey
Re: Can someone recommend a head gasket. I blew mine. [Re: fig426] #329230
05/26/09 03:07 PM
05/26/09 03:07 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
are you running the regular felpros or the performance ones I am running the felpro performance part # 1008 on a 416 with 12.8-1 timimng locked at 37 degrees and have had 0 problems so far.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Can someone recommend a head gasket. I blew mine. [Re: dusturbd340W5] #329231
05/26/09 03:18 PM
05/26/09 03:18 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i really like the edelbrock head gaskets. been on my engine for years
Re: Can someone recommend a head gasket. I blew mine. [Re: dusturbd340W5] #329232
05/26/09 03:50 PM
05/26/09 03:50 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
I believe they are 1008's but I'm not sure. I am really bad at taking notes. The number on the gasket itself is 8553PT with a R12 under it.
Re: Can someone recommend a head gasket. I blew mine. [Re: fig426] #329233
05/26/09 04:29 PM
05/26/09 04:29 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
8553PT is the standard Fel-Pro head gasket, which works
fine with iron head/iron block combinations.
1008 is designed for aluminum heads and more expensive.
No gasket will seal if either the the block or heads are
not machined flat. Studs will help.
BTW,
8553_________12.14 cc volume-.054" thick
1008_________8.77 cc volume-.039" thick
Re: Can someone recommend a head gasket. I blew mine. [Re: S/ST 3040] #329234
05/26/09 04:40 PM
05/26/09 04:40 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
We have been using cometics for around 5 years , have some water seal issues but no chamber problems
Re: Can someone recommend a head gasket. I blew mine. [Re: emarine01] #329235
05/26/09 05:19 PM
05/26/09 05:19 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
And.......... I just pulled the other head and #3 is almost blown through....... So I'll be ordering studs and I'll have to choose a gasket.
Re: Can someone recommend a head gasket. I blew mine. [Re: fig426] #329236
05/26/09 06:21 PM
05/26/09 06:21 PM
Hamiltucky
RBDuster Offline
RBDuster  Offline
Hamiltucky
Chris:
Good news and I guess I was right on the blown head gasket. Go with the 1008 or Cometics and don't look back.
Orange Sunshine Racing
Re: Can someone recommend a head gasket. I blew mine. [Re: RBDuster] #329237
05/26/09 11:44 PM
05/26/09 11:44 PM
S.W. Ohio
clyde Offline
clyde  Offline
S.W. Ohio
At least it's not terminal. Oh,and a few passes!!! sounds like you ran the A-main
Re: Can someone recommend a head gasket. I blew mine. [Re: fig426] #329238
05/27/09 02:10 AM
05/27/09 02:10 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
You will blow the head gaskets quicker with studs. Get ARP bolts. I have assembled a few sm mopars and the ones with studs blew head gaskets. I turned the studs between the threads to 7/16" and did not blow gaskets anymore. To much trouble to do that so I use ARP bolts and never a problem. Above 12to1 stay away from 1008 Felpro and Victor Nitroseal Head gaskets. Use Cometic MLS gaskets for 12 to 1 and up. 2 new and 2 used sets of ARP head studs for sm mopar 4sale
418sm block mopar--hand ported "587" junkyard heads--.590 flat tappet cam--flat top pistons above deck .08--13 to 1--NO NOS--3050lbs--9.68 at 135+--6.09 at 111--1.261 60ft--800+ runs on cometic gaskets and ARP bolts, if I could only get an oil pan to hold up
Re: Can someone recommend a head gasket. I blew mine. [Re: qwkmopardan] #329239
05/27/09 07:32 AM
05/27/09 07:32 AM
S/ST 3040 Offline
S/ST 3040  Offline
Dan, I'm not questioning your method as you must have found something
that solved a problem but, I'd like to understand how using a weaker
fastener works better. Only MLS or any head gasket?
If it works, it works but, I tend to doubt some things, if it doesn't make sense to me.
Stock stroke 340 and iron heads with 13.1:1 here........8553 and ARP studs. I
had fuel/pump issues most of the year with a good bit of detonation. No failures.
I realize, it doesn't make the same cylinder pressure as a bigger engine.
Thanks for your input.
Re: Can someone recommend a head gasket. I blew mine. [Re: S/ST 3040] #329240
05/27/09 07:49 AM
05/27/09 07:49 AM
NC
HMcCandless_Jr Offline
NC
1008 with Studs then retorque the heads on the first startup to 100lbs. then you will have no problem
Herb McCandless Jr
Re: Can someone recommend a head gasket. I blew mine. [Re: S/ST 3040] #329241
05/27/09 12:21 PM
05/27/09 12:21 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Studs were originally intended for engines that are assembled and disassembled frequently. To keep from destroying the threads. 1008 Felpro gaskets are supposed to be no-retorque. Who wants to start up an engine and then remove headers to retorque heads. I want to go racing. Last motor I used head studs on, stock stroke 360, customer had the studs so I used them [knowing I should'nt]. First outing head gaskets pushed into valley 3 places. Disassembled engine cleaned and reassembled engine with ARP head blots instead of studs and it's been 5 years and he still racing it. When I have used studs, I bottom tap block first, install studs untill they bottom out and then back out 1/2 turn, then install gasket and head and torque to 100ft lbs with moly in two steps 50/100.
Re: Can someone recommend a head gasket. I blew mine. [Re: qwkmopardan] #329242
05/27/09 12:27 PM
05/27/09 12:27 PM
Kissimmee Fl.
Kissimmee Fl.
I guess what ever works I am running 1008's with 12.8-1 with studs torqued to 100 lbs no retorque and no problems so far and I have been running the snot out of it.
Re: Can someone recommend a head gasket. I blew mine. [Re: dusturbd340W5] #329243
05/27/09 12:42 PM
05/27/09 12:42 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Me to.
